Heat pump, no energ, in heat mode - Heating & Cooling
  • 2,133 Answers
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Posted on Jan 03, 2011
Why contactor on heat pump will not energize heat mode?
Heat pump and AC are basically working the same principle. When you turn on the heat pump is just like to turn on the AC. The main contactor will energize to turn on the compressor. The only difference is the 3 way valve, either switching to AC mode or heat mode. It is the most commom problem for heat pump. Check the thermostat wires for heat mode and defrost control.
Feb 05, 2015 | Heating & Cooling
Why does lenox heat pump not heat in normal heat mode?
The thermostat is not a heat pump thermostat or it is not wired or set up correctly.
Why does my heat pump trip the breaker in heat mode but not in cool mode?
In the heat mode, the appliance will use excessive current if the heat strips are energized. They energize in the emergency heat mode on the thermostat or if there is a problem with the normal operation of the unit. They also energize when the unit doesn't have the capacity to meet the demand. The reversing valve or its solenoid may be faulty. In either case, call a tech,
Dec 05, 2013 | Heating & Cooling
Heat pump heats with ac cool mode on dometic rv rooftop.
Sound like the change-over valve on the heatpump is not switching. Could be the valve is stuck, or bad. Or the thermostat is bad and will not send voltage, or is sending voltage to your change-over valve.
(Some systems energize the CO valve to cool, while others de-energize the valve).
Usually the color coding for the thermostat wires on a heatpump are orange and yellow. The yellow wire usually energizes the compressor contactor, and the orange wire energizes the changeover valve. Now depending on what your system does in terms of energizing or not energizing the CO valve to invoke heating or cooling mode is not known. You can try jumping across the thermostat to see if the CO valve is working. Or you can even try placing the stat in heating mode and see if you hear that loud "Woosh" when you switch between heating and cooling modes at the stat.
What often happens is the cylinder inside the CO valve gets stuck, especially if the system has sat off for an extended time. By workign the stat from heating to cooling (reversing the porting on the CO valve) will cause the valve to free itself up.
If you cannot hear that woosh as the changeover valve switches between heat and cooling, it is possible the CO valve is bad, or there is an issue in the electrical or control side of your system. Such as a bad base or switching circuit in your stat, or control issues other places.
Sep 03, 2010 | Dometic Rooftop RV Air Conditioner
I have a new 13 seer rheem 4 ton heat pump system the heat pump won't turn on in heat or in other words it is only working in cooling mode I wired it according to the schematic
On a heat pump the difference from heat to cool is the reversing valve.
In cooling or heating the Y1 terminal will always be energized, this is the contactor.
Depending on brand the reversing valve will either be energized in Heat or Cool. At the outdoor unit check to see if the reversing valve is getting 24 volts in cool, if not check to see if it is getting 24 volts in heating. The easiest way to check if the reversing valve is shifting, is to feel the big copper tube, (it is not the suction line on a heat pump) this is a refrigerant vapor line. It will be cold in cooling and hot in heating.
Check your thermostat installation instructions and heat pump installation instructions to determine the proper terminal designations for your heat pump and thermostat. There are some brands out there that use the B terminal as common to the 24 volt circuit, so you have to check the wiring and make sure this is not common.
If it is energized in Cool then the Y1 and O terminal will be energized. You will have 24 volts from common usually the C terminal to Y1 and O.
If it’s energized in Heat then the Y1 and B terminal should be energized. You will have 24 volts from common usually the C terminal to Y1 and B.
If you get heat when you’re calling for cooling or vice versa then switch the wire between the B and O terminals.
Feb 02, 2010 | Heating & Cooling
Gold Star mini split heat pump 24,000 btu. Changed indooe as we as outdoor boards and still goes in cooling mode only. Reset button on outdoor board calls in heat but not by inside hand set. Len Cabana...
Feb 01, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Heat Pump and fan work fine, but will not blow cold air on AC setting
The reversing valve coil may be bad or no power to it during cool. Most heatpumps are set to have the coil of the reversing valve energize in the cool mode. The heating mode is the fail safe mode if the rev valve fails to energize. Check this and let me know.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Lg minisplit heat pump will not heat
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Feb 26, 2009 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
