Question about Kelvinator Refrigerators
The Kelvinator impression series 380 twin air no frost. Model No. NB3800-R Serial No. 450 41105 Just stopped it sounds like it is trying to engage somehing but nothing is happening. the light still comes on, so it has power. Is the thermostat not working? or the compressor? Thank you for your time greatly appreciated James
4 Suggested Answers
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
  • 1196 Answers
SOURCE: I have a Kelvinator 2
he reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on Feb 26, 2011
walterkunesk
  • 683 Answers
SOURCE: I have just purchased a Kelvinator frost free 380
3 is higher than 1.5 and yes some refrigerators/freezers shut off the fan when the temp is satisified.
Posted on Apr 17, 2011
Why is my Kelvinator 400 twin air no frost fridge leaking water under veg compartment
Good morning Barbara, from what you are describing it sounds like the evaporator drain is clogged. You need to empty the freezer and remove any access panels to get to the drain. Get a bowl of hot water and a turkey baster,then use the baster to force the water into the drain to clear the blockage. Not real familiar with that model,so check under the vegetable compartment to see if the drain is under it first. Hope that helps.
Jan 03, 2018 | Kelvinator Refrigerators
Fridge-kelvinator 380 impression series 380 frost free
sadly no question posted gets no answer . we are not mind readers
Jan 14, 2017 | Frost Refrigerators
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
I have a Kelvinator 500L Twin Air No Frost and the freezer no longer freezes anything and the bottom of the fridge is just cold enough but won't respond to temperature adjustment. The motor runs 24/7 as...
I am pretty sure its the defrost timer not working so freezer coil is iced up preventing cool air circulation .you can call me on 0415867792 if you want to know more charles
Nov 11, 2009 | Refrigerators
Kelvinator 380 fridge
Sep 04, 2008 | Refrigerators
Refrigerators Logo
168 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
