Question about Fujitsu 18C1 Air Conditioner
Our Fujitsu inverter although on 18 degrees and "Cooling" on high is not cooling at all. Just feels like a fan on high
  • 2,133 Answers
First advise not to keep in 18 degree temp.(Please ask me why in separate question)
You will get better cooling in 23 degree itself. There are many reasons for not getting cold.
1. Dirty filter and coil. Clean it. 2. Check compressor is working. 3.If working, check for gas pressure. 4. If gas pressure is good, check out door fan motor working well. 5. And also clean your condenser coil.
Helpful?
Posted on Jan 03, 2011
Testimonial: "Haven't tried cleaning the filters or coil but will do so. thank you"
2004 Venture Chevrolet minivan cooling fan circut
Are you talking about the radiator fan? How hot does the engine get in degrees F? Some makes and models, the radiator fan won't turn on till about 220 degrees F. Check for applicable trouble codes, see if any code that refers to the radiator fan circuit or coolant temp sensor? Some of the national brand auto stores will check codes for free.
Of course, as far as overheating in general, you have the thermostat--water pump and other possible issues. Are you losing coolant?
Dec 14, 2014 | Chevrolet Cars & Trucks
How hot does a volcano get
(THIS QUESTION DOES NOT BELONG IN THE COMPUTER SYSTEM COOLING SECTION)
see, for example, http://wiki.answers.com/Q/What_is_the_temperature_inside_a_volcano#slide=1&article=What_is_the_temperature_inside_a_volcano
and associated links
It seems the temperature can be as high as ~3000 degrees (I think this Fahrenheit). From the same sourse it quotes a highest recoded temperature of 5500 degrees.
This
http://www.madsci.org/posts/archives/2001-08/998929728.Es.r.html
article is a good but brief discussion about why it is difficult to measure such temperatures.
18.April2014
Jan 31, 2014 | Computers & Internet
Air flow error message again and again....
A few of these sets did have a issue, the lamp cartridge had some fine metal mesh around a few places where the airflow from the cooling fan contacts it, that mesh if there gets blocked with dust and will give this error as it is really the set detecting the lamp temp is too high.
If you find that, clean the mesh free of dust, careful not to drive the dust inside onto the lamp face itself.
Other than that dust on the fan that cools the lamp can slow the fan just a little and the set will detect this also.
Dec 21, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
We have a fujitsu inverter that is wall mounted - model ASTA 09LCC. The fan is working but the air is not cooling. There is a green timer light that periodically flashes 3 times. Any suggestions?
E3 Outdoor activation of high pressure switch.
Check condenser coil. If blocked, clean it. If out door fan rpm less replace capacitor. Helpful?
Jan 02, 2011 | Fujitsu Heating & Cooling
Fujitsu ducted inverter system not cooling efficiently any more Only 6 mths old
First service your unit completely. And then keep 23 degree for better cooling and then observe for 1 hr.
If no cooling, unit may be running with no gas or less gas and more reasons. Call repairman to locate the exact problem.
Dec 28, 2010 | Heating & Cooling
My heatpump keeps running, but only drops temperature 1-2 degrees. I have a variable speed blower but I don't think that it is ramping up all the way. Air can be felt about 12-18 inches from the registers...
You have a low refrigerant charge. Your low reading which coresponds to the temp at the coil 49psi is about 20 degrees fr. It should be closer to 70 psi depending on the ambient temp indoors. The coil has to be above freezing I usually shoot for 38 to 40. your sub cooling needs to be at least ten. And if you cant feel the heat leaving throuhg the condenser fan it aint moving it.
Jun 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
I'm trying to find out how many cooling fan relays are in a 1999 Ford Taurus SE with the 3.0L Vulcan OHV engine. This model year has done away with the CCRM (Constant Control Relay Module), so the relays...
fuse #9 protects the 2 cooling fan relays.
It looks like the hgh speed cooling fan realy is in a thin box mounted sideways between the battery and fender.
It has high speed relay, autolamp relay, autolamp headlamp relay, horn relay, washer motor relay, wiper hi/lo relay, wiper park relay.
Section 03-03: Engine Cooling 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Electrical System NOTE: With A/C ON, the cooling fan motors will run continuously. Cooling fan motors will not cycle ON and OFF with A/C clutch (2884) .
NOTE: An exception to this is when vehicle speed is over 61 km/h (38 mph) and coolant temperature is below 100°C (212°F), and A/C head pressure is below 1.71 MPA (250 psi). The cooling fan motors will then automatically shut off.
The cooling fan motors are mounted within a fan shroud (8146) behind the radiator (8005) .
Engine Cooling Fan Control CCRM Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM controls the fan operation through the Fan Control (FC) output (single speed fan applications) or the Low Fan Control (LFC) and High Fan Control (HFC) outputs as shown in Table 2. Although the fan control (FC), low speed fan control and high speed fan control relays are normally open relays, the FC/LFC circuit is wired through a voltage inverter inside the CCRM. The voltage inverter ensures that the PCM must turn on (ground) the FC/LFC output to turn the fan off. This is done so the cooling fan will operate in the event of an open FC/LFC circuit.
Stand-Alone Fan Control Relay Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM determines engine cooling fan control requirements and controls the fan operation through the Low Fan Control (LFC) and High Fan Control (HFC) outputs (Table 3).
Jun 29, 2009 | 1999 Ford Taurus
Not booting Properly.
have try to reset bios if not u have to reset bios.
Pullcmos cell for 15 seconds from mohter bord also u can reset bios with jumper settigns it is near cmos read carefully on motherbord u can find jumper u can see "clear cmos " on motherbord
May 06, 2009 | Fujitsu Siemens LifeBook E8020 Notebook
Fujitsu 18C1 Air Conditioner Logo
381 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
