Question about Cameras
Can i get polarid film used in this unit - Cameras
    Brigadier General:
  • 11,967 Answers
Polaroid film is no longer being made. Even if you find some at places like Ebay, it will be old.
Posted on Jan 03, 2011
How to set up polaroid tablet just trying to learn
After having this tablet in limbo for over a year now I decided to contact customer service again but by e--mail this time. First the sent me instructions to hard reset it. I needed to email them again because this unit does not have an outside volume adjustment knob, which I needed to press simultaneously with the power button for 5 seconds. To make along story short the unit is on it's way back to Southern Telecom in Brooklyn N. Y. for replacement!
Thank You for your interest, Davey
Jul 07, 2014 | Polaroid Tablet Computer PMID701
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
System error E007
E007 is a error code for the fuser unit. It means that the fixing film is out of "HP" - most likely the film is torn and needs to be replaced. It will not clear until the problem is fixed.
Feb 26, 2010 | Office Equipment & Supplies
Canon ir 2016j
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
I just rebuilt my Canon PC850 toner cartridge and when closing the unit after installing the cartridge it would not latch like usual. I tried several times and finally got it to latch properly. Once...
Exists much reasons the film could be damaged.Most often of them - is mechanical damage.This can be use fine or thick paper, which rumpled in termo unit. To Install the new film you must required the special knowlege of the service. Do Not advise you to proceed this work without preparing. Good luck
Oct 31, 2009 | Canon Office Equipment & Supplies
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Kodak 3000 DSV Film Scanner , Film Scanner Driver drivers need
You have to Change the scanner vendor name to MS7000 and then use the Minolta Twain driver listed on their web site...USA site!! there are no Kodak drivers for this unit other then the application software Powerfilm.NO kodak windows drivers either , it uses ASPI drivers.
Aug 31, 2009 | Kodak 3000 DSV Film Scanner (35 mm), Film...
Panasonic PV-DV102
there are 2 causes why your camcorder is eating up the tapes; either the tape head is dirty or there is a mechanical fault inside your unit (something might be misaligned that causes the film to be sucked in).
try to clean the tape head of your unit by using a tape head cleaner, it is like the tapes that you use with the unit but instead of a film there is a cloth like material inside that is used to clean the tape heads to avoid the film sticking to it
if the issue still persists then you should contact your manufacturer and set up a repair for the unit
Jul 02, 2009 | Video Cameras
Hobart LT 1 dishwasher leaving film on dishes
The machine is seldom the cause of "film". Make sure the unit is draining proper and that the fresh water supply is supplying good pressure.
Usually film is caused by using residential soap in a commercial unit. The commercial unit cycle is too short for residential soaps to dissolve and work properly. So soap ends up in your rinse water.
Mar 23, 2008 | Dishwashers
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
