Question about Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor
I have a 25hp 46 inch ride on. I have noticed that the speed of the ride on appears to have been reduced slightly. It doesnt seem as fast as it used to be. Any suggestions. Ian
  • 480 Answers
With mine i checked to make sure there was no built up grass in the blade area and around the pulleys and wheels i would also check the tire pressure and brakes to make sure there not binding up.
Posted on Jan 03, 2011
Tip
Riding Lawn Tractors with Hydrostatic Transmission Tip of the Year
Hello everyone! IF you have a riding mower or tractor with hydrostatic transmission you are going to love this insider's tip. Slightly overfill the transmission. Always keep the fluid level about 1/4 inch above the full line on the dipstick. Once you have done this you will instantly notice that the tractor has more speed in forward and reverse. You will also notice that it has more power when mowing up hill. Doing this solved several problems I was having with low power and also slow reverse. I had adjusted the linkage but it did not solve my problem, adding the additional transmission fluid did. Enjoy your more responsive tractor! Joe
on Oct 14, 2010 | Garden
Can i reduce the duct vent size
yes of course you can but if its because your getting to much air you can reduce the fan speed by just replacing the pulley or if it doesnt have a belt drive system it would be cheaper and easier just to install an inverter speed control
Mar 16, 2014 | Mastercool 67471 Evaporative Cooler Air...
Spluttering at low revs
Specifications
The 1991 Honda CBR 1000F uses an in-line four cylinder, four-stroke engine that produces 36.5 cubic-inches of displacement. The engine uses a dual overhead camshaft system and has four valves per cylinder. The maximum power of the CBR 1000F is 93 horsepower at 11,000 rpm and the max torque is 45 ft-lb at 8,500 rpm. The motorcycle's compression ratio is11.3:1 while the bore by stroke ratio is 2.5 by 1.9 inches. The engine is liquid cooled. The transmission is a six speed and is chain driven. The top speed of the CBR 600F is 141 mph.
Dimensions and Features
The overall weight of the 1990 Honda CBR 600F is 460 pounds. The total fuel capacity is 4.36 gallons. The seat height is 32 inches, and the wheelbase is 55 inches. The front tire dimensions are 110/80-17 and the rear tire dimensions are 130/80-17. The front brakes are dual 276mm piston caliper disc brakes while the rear brake is a single 220mm pistol caliper disc brake. The suspension system uses a mono-shock swing arm design. The power to weight ratio is .44 hp/kg. This bike can go 0 to 60 mph in 3.8 seconds.
Appearance and Design
The 1990 Honda CBR 600F features a compact design. Close side mirrors flank a compact instrument panel and tight handlebars. This motorcycle sports a partial fairing that is designed for better aerodynamics. To reduce wind resistance, the legs and feet are fully positioned behind the motorcycle body. Like most sport bikes, when riding at fast speeds, the rider is intended to lie across the fuel tank to reduce drag. No chrome is visible on the bike, as the motorcycle body fully covers the chassis. The display panel features three gauges: a speedometer with built in odometer, a tachometer and a fuel gauge. The 1990 Honda CBR 600F is produced in various combination colors, including white, blue and red or black, purple and orange.
Jan 11, 2013 | 1991 Honda CBR 1000 F
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
I have a 25HP Riding mower. I noticed the last time I used it, it started making a popping noise through the exhaust at the higher speeds. When it idles it seems to be fine.I replaced the fuel filter and...
I would check the exhaust and intake valves clearance. The exhaust valve may be leaking and sometimes improper valve clearance will cause this. Also a dirty carb can cause it to run to lean at high speed and make it do this sometimes.
Sep 15, 2010 | Craftsman Garden
HOW DO I SPEED UP MY PRINTER ON A MFC BROTHER 240 C
The only speed selection is when you select print quality, draft is fastest, and selecting best will slow the printer down to snail speed.
Oct 02, 2009 | Brother Multi-Function Center MFC-240C...
Four cylinder feels like it is only hitting on three
you may have sticking valve or a weak or broken valve spring sometimes an exhaust valve rotator , it maybe that the # 1 cylinder exhaust valve is slightly bent and when it rotates to a certain spot it hangs slightly... requires inspection for confirmation, due a compression test or a cylinder leakdown % test...
Aug 12, 2009 | 1996 GMC Sonoma
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor Logo
185 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
