Question about Hayward Navigator Pool Cleaner
The hose on the cleaner gets all twisted up? - Hayward Navigator Pool Cleaner
  • 640 Answers
Most of the time it is a simple problem that is caused by the way pool cleaners are stored. If you wrap the hose in a coil or around the cleaner when storing it, this is causing the problem. To solve the problem, lay the hose out straight and flat during a warm day. The sun should soften the hose enough to straighten it out. Also, check for obstructions during this time. If the problem continues, you might have too much damage and you might need to replace the entire hose.
Posted on Feb 01, 2011
3 Suggested Answers
  • 64 Answers
SOURCE: Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
Posted on May 19, 2010
jharwell668
  • 640 Answers
SOURCE: New pool cleaner , pool hose just keeps twisting
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Posted on Mar 08, 2011
How do i use the hose on featherlite bagless
Hello! To use the hose on your Featherlight follow these simple steps below.
· Cleaner must be in its upright position. Remove lower hose from the side of the cleaner by twisting to the right and then pull off.
· Remove the hose from the tool caddy.
· Slide the tool hose into the lower dirt hose with the notch facing up. Push together and twist to secure.
· Choose any of the handy accessories or use the hose alone. Simply push the attachment firmly onto the end of the wand or hose handle. To remove tool, twist and pull apart gently.
I have also included a link to the instruction manual if needed. Hope this was helpful!
http://dirtdevil.com/file/661/
May 17, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Pool cleaner floats in water
pool cleaners that twist,wheelie and flop over all most allways a problem with the hose, plastic hose gets a memory that needs to be relaxed once or so a week to keep knots and kinks from forming , also replace hose every 3//4 years to as they just get too beat up to work effectivly any more by then
Apr 14, 2014 | Pentair Legend II Pool Cleaner
I have a Dolphin Pro cleaner. My problem is the 65 Ft cord is so twistered up I cannot fix it. I was told to lay the cord in the sun for hours then try to fix the cord. I can get some of the loops out of...
are you talking cord as in electrical cord /flex or vacuum hose in plastic pipe
if it is so bad that you cannot lay it out straight and it is a plastic hose then it is too old and sun damaged to fix so get a new hose
if it is an electrical cord , get an electrician to fit a new one
Aug 13, 2017 | Smart Pool Inc Dolphin Diagnostic...
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Feb 26, 2011 | Hayward Navigator Pool Cleaner
I HAVE HAYWARD NAVIGATOR POOL CLEANER. MY HOSE TWIST UP WHEN IN USE.
With these pool cleaners, it might not be the hose. It could be that your cleaner head has water and is floating, causing the hose to tangle. Check for that problem. If not, it could be that your hose is too long for the pool size that you have. You might need to remove sections on the hose to shorten it.
Feb 15, 2011 | Hayward Navigator Pool Cleaner
Dirt devil hose is always twisted
Are you storing this pool cleaner with the hose coiled? If so, that is likely your problem. You should never coil the hose on these cleaners because it will cause problems with operation. Make sure to lay the hose flat in its original box or out of direct sunlight when you are not using it. If you start stretching it out flat during storage, it should solve the hose problem.
Feb 14, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Does not move through entire pool but gets tangled at the weir all the time
Is this a new cleaner or old? how old? As these cleaners get old say a year or two, parts wear out and effect the performance. Also a number of other things can effect the performance. For example if the cleaner and hose get left out of water and the hose gets tangled if will develop a memory and can greatly effect the way it runs. sometimes adding a hose or two, or removing, or even twisting each hose a quarter turn with change the way they run. You can often adjust the eyeball return fittings to redirect the water and push a cleaner a certain way or have it avoid an area. Let me know if you need more help
Sep 07, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Hose twists up when in use.
u have to get a hose that has swivels on the ends of them or a rotative vacuum head....hope this helps, let me know
May 31, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
May 16, 2010 | Hayward Navigator Pool Cleaner
Steering, twisting, stopping
Make sure your Transporter Jet (R0376900) is shooting water from all holes. If not, it means you have an obstruction in the jet. You can push a toothpick into the hole that is blocked. If that does not clear the obstruction, you can disconnect the jet from the hose and shake out the obstruction. If the obstruction is a small piece of metal, I suggest you look at your Hydro Time Gear Assembly Kit (R0377000) to make sure the metal did not come from this gear.
Apr 19, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Hayward Navigator Pool Cleaner Logo
748 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
