Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
I purchased a western digital 160G external storage device. My computers tell me that it will be slow without a high speed USB port. However, I get a prompt to install software or to insert a disk into the drive. Help! I know I do not have a high speed USB port, but other smaller storage devices work fine. What can I do to remedy this?
    Scholar:
  • 180 Answers
Use windows xp service pack 2 professional
all the ports are then usb 2 .
if this doe not solve the problem change the circuitry of the ext drive on which you mount the hdd
Posted on Jul 29, 2008
Can someone help me with my external HDD (MY PASSPORT)
Lots of info there, but what exactly is the problem with the drive?
Dec 18, 2014 | Western Digital 1TB My Passport Essential...
Slow transfer
It could be that the USB port you are using to transfer the data is not a "High Speed 2.0" enabled port.
Does it give you a pop-up message when you plug it in, one that says "This device can perform faster".
If so, It is not a High Speed USB port. Try using another USB port on your PC.
Mar 21, 2011 | Western Digital My Book (WDG1C3200) 320 GB...
Western Digital My Passport Essential SE External USB 2.0 Portable Black 720GB Hard Drive too slow..
Try plugging it into a high speed usb port, formating it with the size of your files in mind, so for instance if you have lots of big files, raise the allocation file size and visa versa, otherwise buy a faster one.
Jan 25, 2011 | Western Digital My Passport Essential SE...
Western digital 250 external - not opening
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Nov 11, 2010 | Western Digital WD Passport 250GB Portable...
My Western Digital My Book Essential 1TB External USB suddently won't start,even though i'v plugged in the power cable, theres no lights nor sound coming out from it it just suddently happen out of nowhere
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 10, 2010 | Western Digital My Book Essential 1TB...
I have a seagate external drive of a capacity of 250GB. the free space available is 177 GB. the hard disk is very slow? please help?
Are you connecting this high-speed ("USB 2.0") device to a low-speed ("USB 1.1") USB-port on your computer? If so, and your computer has a "USB 2.0" port, connect your device to that port.
If not, then purchase an add-in PCI card for your computer, to add "USB 2.0" port(s).
Nov 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
High Speed USB controller
You can purchase a high-speed PCI usb card. These are generally inexpensive and can be found at best-buy or perhaps walmart.
Feb 01, 2009 | Western Digital Passport 160GB External...
Western Digital External Hard Drive SN WCAMR4295471
If you are using a pre-Windows xp system you may need to install specific drivers for your HD. If you run xp or Vista Try disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Jan 03, 2008 | Computers & Internet
Slow boot with Vista and MyBook 250GB external USB.
Its the motherboard problem. Just DISABLE in BIOS option in USB tab: SUPPORT USB LEGACCY - or similar to this. This helps on 90percent of motherboards.
Regards Silver
Dec 20, 2007 | Western Digital 250GB MyBook External USB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
124 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
