Question about Archos 605 Wifi Portable Multimedia Player
The archos 605 say the USB cable is attached but the (buttons are Temporarily disabled)
  • 3 Answers
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Posted on Jan 31, 2008
oblina
  • 5 Answers
SOURCE: Archos 605 battery replacement
I just found a place to buy a replacement battery (http://www.newmp3technology.com/605-30-battery.htm) and I was wondering if I can change it myself?
Posted on Sep 02, 2008
SOURCE: Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Posted on Sep 18, 2008
SOURCE: PC no longer recognizes my Archos 605
I had the same problem with my Archos 605 and here's how I fixed it....
Right click on My Computer, then click on Properties. Under the Hardware tab click on Device Manager. My Archos was shown under Portable Devices but with an exclamation point next to it. I right clicked on Archos 605 wifi and then clicked on Update Driver. This updated the MTP driver and now everything is working fine.
Posted on Sep 30, 2008
SOURCE: 605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Posted on Nov 17, 2008
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
Jul 15, 2009 | Archos 605 WiFi Digital Media Player
Message appears saying buttons temporarily disabled
It just means that you can't use the device while it's connected to the computer. The buttons are enabled again when you disconnect the device.
Feb 09, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
May 22, 2008 | Archos 605 WiFi Digital Media Player
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Think i have broken my archos 605
Go to the archos website on your PC and download the latest firmware. Once you have the firmware downloaded to your desktop, connect your archos to the PC with your usb cable.
The computer should recognise the archos as an external drive.
Open the archos drive on your desktop and drag the new firmware into the window. The computer will copy the new firmware onto the Archos drive.
DO a safe disconnect from your pc and restart your archos. The new frimware should start to load itself on your Archos when it powers up. You will need to reconnect the usb cable for the downlaod to start running. Once it is finished it will restart itself again. You will probably need to recalibrate your touch screen interface as well. You need to use the buttons on the side of the unit to scroll through the menu to get to the "settings" screen, and then the "display" screen. Choose "calibrate touchscreen" and follow the instructions.
I hope this helped.
Mar 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi problems
What does the USB cable have to do with the WIFI
Mar 09, 2008 | Computers & Internet
i have xp professional it was working 2 days ago i downloaded tons of stuff now i the same computer can'T see it but not just my computer i tried on 3 different computers it sas usb is connected (buttons disabled) but computers doesn'T see it.. but it keeps on chrging itself !
Dec 23, 2007 | Archos 605 WiFi Digital Media Player
Archos 605 Wifi Portable Multimedia Player Logo
145 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
