Question about Frigidaire GLEQ2152ES Electric Dryer
The dryer is making a thumping noise and taking longer to dry.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
MNTECH
  • 1543 Answers
SOURCE: Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Posted on Dec 06, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Posted on Jan 21, 2009
  • 5 Answers
SOURCE: dryer makes a thumping noise when running.
replace drum wheels.
Posted on Jul 16, 2009
Has a thump thump noise as the drum goes around, no problem drying, just thumps.
The belt might be about to break. Check that. Sometimes it may split and still operate but the dangling piece of belt will hit something inside an make the noise.
Sep 15, 2015 | Dryers
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
My Kenmore 80 Series gas dryer is making a loud thumping noise when running. It appears to still be drying, just making a very loud noise. What could this be? If it's the roller, approximately what is the...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 04, 2011 | Dryers
Dryer is making a thumping noise while drying.
heatman101
Jan 30, 2011 | Frigidaire Dryers
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Our dryer gets hot how ever it takes forever to dry a load of clothes and it makes a huge thumping noise; what could this possibly be.
the thumping is the drum not moving around right you need to change the felt the vent hose must be tight and stright up and out no slack moister needs to be blown out
Feb 18, 2009 | Dryers
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
186 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
