Question about ASUS M2N68-AM SE2 Motherboard
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows (no Siganl) 2. i check the smps (its ok) 3. after the fan stopped rotating, the motherboard green light is continually blinking 4. No any smell in PC i request u to give good solution for above mentioned problem please sir
    Scholar:
  • 64 Answers
This could also be an issue with the power supply. Perhaps it's transistors, or a fuse is fading, and it's not able to correctly regulate the power going to the motherboard, so the motherboard is shutting it off. I've had this happen on quite a few of the older systems that I've fixed over the last decade.
Posted on Jan 08, 2011
    President:
  • 2,022 Answers
Remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Jan 03, 2011
I can't Enable audio after instaling window 8
Sound like you lost the driver or is not compatible. Here are your specs and downloads. The newest one is for Win 7, but it's worth the try. It worked for me.
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#download
Sep 23, 2012 | ASUS M2N68-AM SE2 Motherboard
Good day sir can you help me about my ethernet driver i lost my cd ASUS M2N68-AM SE2 ethernet controller driver thanks
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Sep 08, 2010 | ASUS M2N68-AM SE2 Motherboard
I have asus m2n 68 se2 motherboard and amd processor.when i press the power button ,the cpu fan just run then off. .cmos cleared
Before anything you should suspect the power supply. It may be able to start the board for a second, but doesn't have the oomph to keep it running.
Aug 09, 2010 | ASUS M2N68-AM SE2 Motherboard
Drivers for ASUS M2N68-AM SE2 using server 2003
you will get driver from http://support.asus.com/download/download.aspx?SLanguage=en-us
you need to search in search box with the term M2N68-AM SE2 and you need to select Operatin system from dropdown menu..then you can download all drivers
May 14, 2010 | ASUS M2N68-AM SE2 Motherboard
No beep, no display in new asus m2n68-am se2 motherboard
Try booting the system with a bootable and well memory stick and probably check the power switch if it send any signal to the board while pressing it.
May 07, 2010 | ASUS M2N68-AM SE2 MicroATX Motherboard &...
When i power on cpu fan start initially and then sop
try to change your fan proccesor or your power supply adapter for your CPU
Mar 12, 2010 | ASUS M2N68-AM SE2 Motherboard
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
Oct 16, 2009 | ASUS M2N68-AM SE2 Motherboard
ASUS M2N68-AM SE2 Motherboard Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
