Question about Maytag Dishwasher
Burning smell with ticking noise water in bottom but not spraying or draining.
  • 472 Answers
You may want to remove bottom kick plate if you look in there you wil see the main pump housing and to the left is a drain solenid that has a actuator allowing it to move up and down and this is what opens the pump to drain and pump.... alot of times this solenoid will go bad and sometimes literally melt and get stuck causing the odor you are describing and the problems....hope this helps good luck and please vote.....
Posted on Jan 03, 2011
How do I fix the smell coming out of engine area. everytime it turns on it smells.
Hello friend, thank you for your inquiry!
I understand that you are receiving a smell from the engine area of your Frigidaire refrigerator. I would recommend cleaning your drain pan area, you can do that by using water and bleach in a spray bottle then spraying it into the drain pan. Also, get a vacuum attachment to help suck out any debris located in the drain pan. You can also seek consultation with a professional technician for additional assistance if needed. I hope this helps. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Loud noise while running
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Mar 22, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
It does not drain at all? and it makes a weird noise and it smells like burning rubber how do i fix it? some one told me that it might be the pump.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
Mar 27, 2010 | Maytag MAV2755AWW Dependable Clean Top...
Agitating, ticking noise and then burning rubber smell
HI, the motor is failing slowly and, i recommend replacing this damaged motor asap before it starts to over heat and present a fire hazard.
Jun 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My bissel 7901 won't spray water out of the bottom or hose to clean the carpet. I did smell a burning smell and shut it off. Is the pump gone?
Depends, if the the smell was like rubber, then it may be the pump belt. If it is ok, then the pump could be bad, altho the pump wouldn't have had a burning smell. The main motor would if it was an electrical smell.
Apr 14, 2008 | Vacuums
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Ticking noise
you need to replaced the lamp and lamp power sulppy board. the ticking sound is from the lamp board tring to start up the lamp. The lamp is blowed out
Aug 30, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Maytag Dishwasher Logo
226 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
