Question about Jet 3 Ultra Power Chair
We have been given a Jet 3 ultra motorized wheelchair and have lost the offboard charger. I have looked online and can find only on-board charging cords. What do I look for to find a new power cord?
    Scholar:
  • 63 Answers
The power cord you are looking for is just about the same as your power cord plugged into your computer,you can find on just like it at your local radio shack or office depot . Have a good day hope I was able to help.
Posted on Jan 14, 2011
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
Batteries quit charging. installed new batteries. new batteries will not charge
check at the rear of the chair when you plug in the on-board charger the meter shoud go up to indicate charging if the meter doesn't move recheck the battery installation to make sure that the wiring is correct I had one the other day that had crossed the connectors and was getting neg voltage instead of pos and the charger or the chair won't work. If the wiring is correct and you aren't getting a charge indication on the meter I would suspect the charger If you can borrow an offboard charger you can charge your chair through the joystick charger port under the front of the joystick until you can get a new charger. I would buy an offboard if you have to pay for it yourself it will be cheaper. Hope this helps
Mar 29, 2011 | Jet Health & Beauty
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
Chair dont take a charge
Get new batteries If your batteries are 2-3 years old its time for new ones. You can check the output of the charger by using a digital voltmeter Set the meter to 200 vdc and plug it into the two outter holes of the charger port with the charger plugged in you should read 27-30 volts. and with the charger unpluged you can aslo read the voltage of your batteries. fully charged they should read 25 -27 volts. If when charging you don't read 27-30 volts then the charger isn't working and you can get an offboard charger cheaper than the onboard just charge thru the charger port on the joystick. Hope this helps
Feb 03, 2011 | Jet 3 Ultra Power Chair
Batteries won't charge, bought new batteries and they won't charge either
Moore well it looks like you have a charger problem. With a digital voltmeter plug the on-board charger into the wall then take the voltmeter and plug the two leads into the two outter plug holes of the charger port under the front of the joystick set the meter to 200 volts dc. with the charger plugged in you should read 26-30 volts if you don't get that you are reading just the current battery charge 20-24 volts. If you can try to find someone locally that has an offboard charger and borrow it for a few hours. Plug the offboard charger into the charger port under the front of the joystick and let it charge the new batteries. I would try to find someone with an extra charger you could buy or contact your local provider and have them get you an off board charger to charge your chair. Hope this helps you
Sep 23, 2010 | Jet 3 Ultra Power Chair
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jet 3 Ultra Power Chair Logo
80 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
