Question about LG DLE2532W Electric Dryer
Wouldnt dry no heat, checked dryer hose, it was full of wet lint, we cleaned it out but still no heat?
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Take to much time to dry
Dear Ms.B.
I'd start by unfastening the vent hose off the back of the dryer and running the hot air into the room or with a large pipe out a window, to see if the vent pipe is plugged to the outside. If that does not speed up drying, check to make sure the washer is not at fault, by the wetness of the clothes. A loose belt can let the clothes be too wet from the washer. Then, I'd take the whole dryer apart and clean the inside. In the past 3 months, I have had 3 different dryers that were full of lint, over a two shoe-boxes of lint inside each one. The reason for the buildup is poor design, and each dryer was many years old.
Be blessed.
Jan 08, 2014 | GE 3.6 cu. ft. Electric Dryer - DSKS433EB
I have had this elect dryer for about 3 years. Same prob from the start.. Takes forever to dry any load of clothes.. Litterally 4 plus hours to dry 5 bath towel and 6 or 7 wash cloths.. this is...
Long drying times can commonly be the result of improper or restricted venting.
Examine your vent hose. How long is it? Too many bends?
Check to make sure your vent hose is clear and free of an restrictions.
If vented outside, is the flap opening properly and free of lint buildup and is the hose clear?
Pull your dryer away from the wall and disconnect the vent hose, use a vacuum or brush to clean out the inside of the hose, sometimes shaking the hose a bit (if possible) will free any lint buildup that your vacuum or brush may have missed.
Don't overlook cleaning out the pipe that the hose connects to on the back of the dryer.
Lastly if you have a lint filter that's on the top like mine, remove the lint filter and check for obstructions there, use a lint filter brush and clean well, this is often overlooked and a major cause of poor drying, overheating, or fire.
Feb 11, 2011 | Dryers
Dryer heats up, but wont dry clothes
Check and clean your lint trap in the dryer.
Check and clean your hose, this could cause a fire if the hose becomes plugged with lint.
Also check your blower in the dryer to make sure the blades are ok and not broken.
Normally these are the cause of clothes not drying if the heating element is working.
This is a FREE answer, Please Rate Me
Oct 01, 2010 | Frigidaire GLGR331A Gas Dryer
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer does not dry
Problem is likely:
- heating element, or
- one of several thermal limit switches in the electrical circuitry
If you want to further pursue, let me know.
Apr 28, 2009 | Kenmore 73952 Gas Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
LG DLE2532W Electric Dryer Logo
53 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
