Question about Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook
Bsod error code 0x00008e i've tried to restore and all of that
  • 942 Answers
Try to restart pc and repeatedly press F8 to boot to safe mode. If it is no good, turn off the laptop and then remove the cables and battery on it. Then press and hold the power button for 8 secs. Then reinsert cables and battery. Turn on the laptop, if the blue screen occurs, you need to reinsert the operating system CD. Contact a pc manufacturer to back up the hard drive all your files and then reinstall the operating system using a CD...
Posted on Jan 03, 2011
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Tip
How to fix Blue screen of death (BSOD)
BSOD--- Blue screen of death So guys how to get your computer working if you get a BSOD...???
XXX0000000XXX
well first of all check the exact error code and figure out the cause of it,there could be multiple reason
Bad memory
Bad sector in Hard disk
Registry error
Virus/Trojan/Spyware
Keep the windows disk ready....u might need it
Try the advanced boot menu...
See if you can get through F8 key helps a lot
Try last known good configuration.....
If not then try Safe mode with command prompt,if you can get through then use the system restore u need to be a 'C' prompt by using CD command and then pen the restore console (%systemroot%\System32\restore\rstrui.exe)
Otherwise do a flee power
No go yet.....
Hummmm u need the disk bro
Boot with CD (f2 or F12)
Run Chkdsk /p and chkdsk /f on he recovery console
still no go................
Please comment buddy
post a reply
on Jun 13, 2010 | Computers & Internet
When connecting to VPN and laptop and wireless, bod
You can try this- Perform system restore on when the last time your computer worked on wifi- Re-install Network adapters and softwares related to your network- Try windows update- Get the BSOD stop error codes then check it on http://aumha.org/a/stop.php
Mar 14, 2012 | Cisco Linksys E1000 WirelessN Broadband...
My computer starts to boot up then pauses for a while.Gives a flick of a blue screen. Then re-boots again.
Anyone using Windows has likely experienced the infamous 'Blue Screen of Death', a.k.a. 'Windows Stop Error'. This is a common error that occurs whenever Windows senses a software, hardware, or driver error preventing it from operating properly. So basically, almost anything from a minor glitch to a major system malfunction can cause this error to appear.
Sometimes this problem will go away with a simple reboot and you may never see the blue screen again. But more typically, the Blue Screen of Death (BSOD) is an indication of something serious and it will not simply go away. In terms of how to fix the Blue Screen of Death, there is no simple answer to that. Fixing it means first diagnosing the problem to find out what is wrong with your PC.
First, a quick explanation of what the Blue Screen of Death is. This error occurs whenever Windows detects a serious problem from which it cannot recover. The operating system halts all operations and it displays diagnostic information on the blue screen. All Windows XP stop errors are numbered according to the circumstances that caused the error, these error codes can help in the diagnosis so it is a good idea to write down the error code whenever they show up.
If you are not one of the lucky ones who can fix the BSOD with a reboot, then you will need to do some diagnosis to resolve the problem. With all the possible reasons for the BSOD ranging from software to hardware, or hardware drivers, it is very difficult to list a precise set of instructions for every possibly BSOD. The first step is to narrow down the possible source of this problem.
If you are seeing the BSOD randomly, even when in safe mode, chances are it is a hardware issue. If you have recently installed new hardware, this may be the culprit. One solution may be to remove the new component to see if the problem goes away. If you have not installed anything new, then you will need to investigate further. If you are not comfortable unplugging and re-installing hardware in your PC, this may be a good time to have a technician look at it.
However, if you have ruled out a hardware issue, then you will need to start up your PC in safe mode. The first thing you should try in safe mode is a virus check and spyware scan of your entire system. If anything was found, eliminated the problem then try to restart Windows XP again in normal mode.
If nothing showed up on the scans, then boot up again in safe mode and use the built in system restore utility. When running your system in safe mode, you can still access all the recent restore points created by the system restore utility. Run your system from the last known 'good configuration'. On the other hand, if you know a recent software installation is the cause, then restore to the point created at that date.
If none of these suggestions has fixed your problem, then you will need to delve even further into troubleshooting this error. If you were able to copy down the information from the blue screen error message, you can try searching online for some further advice or suggestions on how to fix it. For any error that you encounter, there are probably many others who have experienced it before, so you may be able to get some answers with a little research. The bottom line with this error is that you will need to be patient as it may require a lot of trial and error.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
How do i repair a blue screen of death
restart your system manually. If BSoD appears on every restart, then try to remove theproblem which it is referring to. Try using Windows Recovery cd. Once the Windows boots, go to System Restore in Control Panel and roll back to the most recent restore point.
Or else re-install Windows and check.
Normally BSoD appears if there is a critical hardware/memory error.
Sep 19, 2010 | Computers & Internet
I have BSoD on my dell inspiron mini error code 0x0000007B. i have read several posts telling me to download various types of repair programmes. How do i get rid of the BSoD to enable me to download such...
Try installing ubuntu to at least get you up and running so at least you can surf the web and check your emails etc. Then either try a windows repair disc or see if trinity restore has an options to fix your os.
Aug 28, 2010 | Dell Inspiron Mini 10 Notebook
Blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
IRQL_NOT_LESS_OR_EQUAL error with BSOD
If you can run it in safe mode, have you tried doing a system restore to a previous restore point (one that was at a time when you could start the machine)? Sometimes software or drivers that are installed can cause problems and restoring back to a previous good state may resolve the issue.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/app_system_restore_hss_safemode.mspx
Oct 02, 2009 | Dell Inspiron 1545 Notebook
Bsod problem due to reliance lxu 800 usb modem drivers
Hello dear, I'm one of the users of LXU 800 modem. I tried all the sources and found there is no way resolving this issue because the manufacturer has not yet released any updates till now. I also heard the team at Reliance doesn't care about this issue because the actual manufacturer is LG. Anything to share? Meet me at 3hackerdude3@gmail.com. Have a great day. Yours truly, N Bhargav Reddy.
Aug 15, 2009 | Computers & Internet
Dell Inspiron 1525 (dndppa1_3) Intel Core 2 Duo T5550 (1.83GHz/667Mhz FSB/2MB cache) 120GB/3000MB PC Notebook Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
