Question about ION Audio Ion Discover Dj Computer Dj System- Includes Everything
I cannot listen to a song through my speakers and a different song with my headphones at the same time.Either I hear one song or the other but never the two at the same time..any ideas why?
  • ION Audio Master
  • 5,603 Answers
I believe that only ONE audio system can be active at once so what you are observing MAY be normal. The pro DJ units have two seperate CD players and are set up to cue with headphones. See if you have a "cue" control on your system... Often the clue to these problems is in the manual which one needs to know the name of the function to search for. Learning the language is the key as indexes are useless without the "word".
Posted on Jan 03, 2011
Yamaha cp33 has no volume when key is pressed
One key? or all keys?
if one key- the switch contacts for that one key are where to look for dirt, corrosion or broken wires.
If one octave- check wires and connections on the borad that set of wires lead to, and look for bad solder joints or bulging capacitors, or evidence of a spilled beverage.
If all keys, Check to make sure the mute button is not pressed. and volume level is up, and see if headphones will work with it. If you are using headphones- try a different pair first, you may have a broken wire in the headphones Then check the wiring inside, especially the wire for common buss connection. Also check the amplifier for funtionality. This is simply done by pressing a screwdriver in contact with the amplifier input, you should hear a buzz out of the speakers of the keyboard or through the headphones. The amplifier borad is the one with wires to the headphone jack and speakers.
Oct 27, 2012 | Williams Encore Digital Piano
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
Piano does not work no sound can be heard power supply is on display is proper too. if head phones are used i can hear the sound. but no sound can be heard without headphones tried to play a song through...
I could not find the schematic for this, but other Casio units use a common voltage regulator amplifier chip to drive the speaker... I would firsst check that leads to the speaker have not become disconnected.
Jul 19, 2011 | Casio SA76 44-Key Mini Personal Keyboard...
Im using my vestax vci 100 mk2 with my macs built in speakers.i am only able to hear the sound ouy of my headphones and if i choose built in speakers as an option in the set up wizard i can only hear the...
It is an either/or thing. I would recommend you get a headphone amplifier or get external speakers and drive them externally. Internal speakers are relatively poor quality anyway
Apr 28, 2011 | Vestax Vci 100 Midi Controller
When I listen to my amp with headphones the sound seems to come and go.
I have a 250 gfx, and I have had the same problem intermittently, I have concluded that the digital fx section is to blame, as it is also responsible for the speaker modelling for the line/headphone jack, and I have also had problems with my fx section.
If you have anything in the effects loop that boosts signal volume remove it, a small boost in the loop gives the power amp in these a nice glassy sound, but seems to be (in my case at least) responsible for the failure of the fx/ emulated line out.
Also check all your leads and headphones cord, try some different headphones if you have them.
Apr 03, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
Shure Srh 240, new headsett I bought and although the sound is good, I cant get the same volume as with my koss headsett, although I'm playing through my phone at the moment. is it has anything to do with...
I have also experienced differing volumes when using different brands of headphones (I have worked as a sound engineer part time in the past.) It's usually due to a difference in impedance between the different speakers using in the headphones (sometimes the impedance will be indicated on the headphones like 16 ohms.) If the two different kinds of headphones have differing impedances, the apparent volumes at the same level settings will be different
Feb 28, 2011 | Shure SRH240 Two Pack with HP4 Headphone...
When i plug in a external drum machine or ipod to aux in, i cant hear it out the speaker and only through headphones
This is how it is designed to operate - the aux input is for practice use only and is only routed to the headphones socket and not the speaker. Your only options are to use a different amp for your IPOD or drum machine or to use a mini-mixer to input the combined signals of guitar and IPOD through the single input socket on the BG500
Jan 30, 2011 | TC Electronic BG500 - 115 Amp Combo Bass
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
Jan 17, 2011 | Yamaha Full-Size Keyboard
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
ION Audio Ion Discover Dj Computer Dj System- Includes Everything Logo
240 people viewed this question
Top ION Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an ION Audio Music Expert? Answer questions, earn points and help others
