Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
The vacuum was on when my son tripped the cord and one prong broke off in the outlet. We patched on another cord. It won't turn on tried other outlets. Can't find reset switch, is there one or did we burn out the motor?
  • 694 Answers
Maybe you got the wires crossed between the two cords. Vacuums have polarized plugs and if wired imcorrectly can definitely cause the vacuum to not work. Try switching over.
In other words, consider current wires as A1/A2 and B1/B2. Disconnect, then connect A1 to B2 and A2 to B1.
vacuum===============A1 A2=======Plug
===============B1 B2=======Plug
Switch to
vacuum===============A1 B2=======Plug
===============B1 A2=======Plug
Try this and see what happens.
Posted on Jan 03, 2011
How do I get the vacuum to turn on now?
Just to cover all bases, have you tried an outlet on another circuit? It sounds as though the vacuum (motor perhaps) shorted and tripped the breaker.
Nov 15, 2017 | Miele Vacuums
My dyson won't turn on when plugged in ..seems problem with prongs on plug
It seems that it could be a problem with your power cord. I would start by checking to make sure it is good. If so, then check the switch next.
Mar 22, 2016 | Dyson DC07 Low Reach Vacuum Cleaner...
What does prong mean
A prong is usually a piece sticking out. Your vacuum has a power cord that plugs into the wall outlet. The metal pieces coming out of the plug that go into the wall outlet are called prongs.
Mar 12, 2014 | Vacuums
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Gary
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
Vacuum is turning on and off intermittently
Turn the vacuum ON.
Go to the plug while it is in the outlet, jiggle it and the wire going into it to see if there is a loose connection on that end.
Then go to where the wire enters the vacuum.
Jiggle that to see if that makes the vacuum stop.
If there are no problems found on either end of the wire, the next step it to open the machine and check the connections at the internal switch and the switch itself.
Let us know.
Gary
Jan 29, 2011 | Hoover Breathe Easy U5250-930 Bagged...
When I insert the hose into an vacumn outlet nothing happens. I tried pressing the reset button but still nothing.
First, make sure the unit is still plugged in.
2. Ensure the circuit breaker has not blown. This is easily checked by simply plugging another item into the outlet. If it has blown, flip it back on. If it continues to blow, there's a short in the cord or wiring of the vacuum.
3. Is it just one outlet, or all of them. If it's just one, it needs replaced.
4. Check the prongs on the hose, wands, and power nozzle to ensure they haven't shorted out.
5. Use a multimeter or continuity tester to check wires in the hose. Touch lead of the mm or ct to a prong on the hose, the other lead to the connector on the other end of the hose. Check both connectors. One should show continuity, the other will not. Repeat for other prong. If either prong shows zero, hose needs replaced.
6. Motor is burned out and needs replaced.
There are other problems that could cause this, so I recommend taking it to the Broan-NuTone dealer you got it from for them to check the vacuum for problems.
Dec 19, 2010 | Broan-NuTone CV353 Central Vacuum
Is it worth trying to fix the end of the power cord that goes in the wall outlet? One of the metal prongs broke.
You can buy just the end at the local hardware store. This is the best way to fix it. It is also the safest way to do it and not risk electric shock.
Jun 26, 2010 | Eureka Whirlwind 4383 Upright Vacuum
Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Mar 24, 2007 | Rainbow 75th Anniversary Canister Vacuum
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
238 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
