Question about Tamron AF 28-200mm f/3.8-5.6 LD Aspherical Lens
Tamron AF 28-200mm 3.8 - 5.6 Apherical LD that was used on a Nikon 5005 SLR. Would this lense fit a Nikon D40 digeital camera?
  • Anonymous Mar 18, 2014
    Tamron AF 18-200mm 3.8 - 5.6 Apherical LD error 99 canon
    Scholar:
  • 175 Answers
It will fit but no AF.
Posted on Jan 06, 2011
I have dust particles inside my Tamron 17-55 LD XR DiII SP Nikon mount lens. Is there an easy way to remove them?
No. There is no easy way to remove them, to do so requires an expensive strip down and overhaul in a clean dust-free environment.
Unless you have the dust equivalent of boulders in there, then they are highly unlikely to show on your images and you can ignore them. Even if they do show occasionally you can usually easily correct the faults using commonly available processing software.
Jul 12, 2011 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
What nikon camera will this mount to
Tamron is a third party lens manufacturer and make lenses to fit all popular makes of cameras both film and digital. I'm sure the top two would be Canon and Nikon. So if the lens you have there is a Nikon Mount it will fit Nikon Auto Focus cameras both film and digital
Jan 04, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
What type of lens works with this Nikon N8008s AF 35mm SLR? Thank you, Larry
Any of the Nikon Auto Focus(AF) lenses should work fine with it. There are also a number of fine aftermarket lenses made for your 8008, by Sigma, Tamron, Tokina, Quantaray and others. Be sure you get the Nikon AF lenses, as they make the same lenses for Sony and Canon. You cannot use the Lenses made for another brand, as they will not fit, work right, and can damage your Nikon.
Jan 25, 2010 | Nikon N8008 AF 35mm SLR Camera
I just bought a tamron di 2 AF 55-200mm f/4-5.6 LD macro for my nikon D40 and i can't get it to autofocus
That 2x is not AF-s compatible. It is the older Af style which the d40 does not support. Your camera store should have known this when they sold it to you, unless you bought it mailorder. Then see if they will let you return or exchange it.
Nov 04, 2009 | Tamron Autofocus 2x Teleconverter Lens for...
Nikon D40x
you will not have AF...only MF
full list of compatible lens for your camera here
Oct 16, 2008 | Tamron SP AF 11-18mm f/4.5-5.6 Di II LD...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Jan 15, 2008 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
Cameras Logo
272 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Tamron Camera Expert? Answer questions, earn points and help others
