Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
When i cut on heat run about 45 cut off smoke blue?
  • All-Pro Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 03, 2011
What causes my 1994 lexus gs300 to start smoking an running rough an cuts off. white fuel smoke.
'white smoke' is in fact steam which leads me to think your head gasket has gone which would explain the running rough. Is your coolant going down? You can hire a pressure tester for the coolant system.
White smoke is steam
Blue Smoke is oil
Black smoke is rich mixture, too much fuel
Aug 02, 2017 | Lexus Cars & Trucks
Bought a ys4500 24hp craftsman mower off Craig's list! It runs great but it blows light smoke blue in color and not have good cutting power! I have drive slow to cut decent! What could be the problem?
- Make sure the blades are sharp
- Make sure the drive belts are in good condition and under tension when in cutting position
- Make sure that straight gas is in the fuel tank (NOT MIXED)
Other problem could be bad piston rings. PITA to fix. If it runs good and cuts ok after the above checks, I'd run it and live with a bit of smoke.
Jun 22, 2015 | Craftsman Garden
Blue smoke from exaust then after twentyfive minutes the push mower begins to sputter and blow alot more smoke.Its a yard machine 4 hp 22" cut.What is it and can it be fixed cheap.Or should i just buy...
Blue smoke would indicate its burning oil. Oil is bypassing the piston rings or valves and is entering the combustion chamber where it is then burnt off.
Small engines are easily rebuilt, usually less than $100, most people just run it until it drops or buy a new mower.
Jun 04, 2014 | Garden
I have a 5L-E toyota hilux that runs fine at idle yhen when you rev it to about 2000 rpm it starts to blow alot of white smoke. I have cut injectors out while the smoke is blowing with no noticable...
i believe the engine is running too lean as if it was running too rich it would blow black smoke If it was blue smoke it is oil related eg valve stem seals,valve guides and or piston rings all of these things will create blue smoke if one of the above is worn out
Mar 26, 2014 | Toyota Hilux Cars & Trucks
Low power, blue smoke, engine cutting
blue smoke indicates oil is burning in the cylinders. This is either leaky valve seals, (little blue smoke when engine first starts, but stops smoking shortly after) or the worse problem, worn rings. What happens is when your rings are worn, they let oil get past the rings and into the combustion chamber, AND it also lets out your combustion pressure (your power source) into the crankcase, so you have considerable power loss. Only way to fix worn rings is to rebuild the engine, as just replacing the rings would require complete teardown of engine anyways, and who wants new rings in a worn out motor.
Dec 17, 2013 | 2006 Volkswagen Jetta
Jeep 4cyl flathead smoking
White or blue smoke? If white does your hand get damp holding up to the tailpipe when the engine is running? Does the radiator boil over/engine over-heat easily? Flat head engines are notorious for running hot especially if not moving. Flat-heads don't cool well as a general rule and the older radiators are not very efficient heat exchangers. If the smoke is white then the headgasket is blown or the head or block is cracked (the first two are more common). If the smoke is blue then the valve guides and/or the piston rings are worn fairly severely. Ironically the easiest way to damage the piston rings or valve guides in a flat-head is to run it hot.
May 13, 2013 | Cars & Trucks
Have to hold gas pedal to floor to keep car running.wont go over 45 with it floored.and there is blue smoke from exhaust
i would suggest checking into the throttle positions sensor. the smoke makes it sound like the car is flooding.
Apr 18, 2010 | 1999 Nissan Maxima
Blue smoke from 7.3
probably the oil rings on the pistons but might be one of the heads , not good either way
Oct 09, 2008 | 2001 Ford F350 Super Duty SuperCab
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
128 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
