Question about Buffalo Technology MiniStation Turbo 120 GB USB Hard Drive
I can't conect exteranal harddrive Buffalo Model:HD-PE250U2 to my desk top cumputer,after conect by USB conector it show that " you need to format drive befor open" how can i solve this problem ?
  • 10406 Answers
SOURCE: WHEN I PLUG MY EXTERNAL
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
  • 10406 Answers
SOURCE: Will Buffalo Model HD-PE250U2 work
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Posted on Dec 31, 2010
  • 21 Answers
SOURCE: i formated my buffalo ministation 160gb harddrive
omega
Posted on May 13, 2011
bronk50
  • 27725 Answers
SOURCE: Windows Xp won't recognize external harddrive buffalo hd-hs2.0TQ
When you connect it up, are there any lights that turn on? Do you hear any mechanical sounds from the external unit?
(Where do you look in your laptop? In My Computer, does it simply not show up there?
Click on Start ... Control Panel ... System ... Device Manager.
Can you see the device in Disk Drives, or in the USB device listing?
If so, does it have any Caution tags on it?
If you right-click and ask for its Properties, what does that say?
Back out of all that.
Click on Start, then RIGHT-click on My Computer, click on Manage. In the left pane expand Storage if necessary and click on Disk Management. Look in the LOWER RIGHT pane and scroll through all the hardware devices it shows there.
Do you see that external drive there?
If not, you have a hardware problem.
IF you can see the unit in Disk Management's lower right pane, look at the main block which has info on it.
It will show a Volume Name like My Disk or something, a Windows letter name like E, a size, a File System like NTFS, and a status. What are those?
If it simply has no letter name you can assign one by right-clicking on it.
If its File System is shown as "RAW", you have a little corrupted info in the disk control files. It may ask if you want to Format the disk and you are right to NOT do that.
3. Does it display the same info if you connect it to another PC?
4. IF the unit lights up but does not show anywhere as a valid piece of hardware, it is still possible that the HDD inside it is OK with good data, and the problem is with the case - its power supply or communication interface chips.
If that is the case, a simple way to check is to open the external case , uninstall the HDD unit inside, then install it temporarily in a desktop PC.
BUT your external unit MAY be one designed for use with laptops, and those have slightly different connectors on the, you would need an adapter to make the connections to the desktop machine.
But if you can do that, a good HDD will just show up like any other installed HDD. If that happens you can look more closely at the empty case as the culprit.
hope this helps
Posted on Sep 11, 2012
my usb buffalo is reading but not showing drive
Posted on Mar 07, 2013
I cannot read anything on my buffalo HD-PE250U2. What's wrong? It works fine all the time till yesterday.
Try different cables, then try to open the unit and plug in the hard drive directly into the machine to see weather ti drive itself has failed.
Jan 09, 2014 | Computers & Internet
Data error(cyclic redundancy check)
harddrive is dead or bad sectors, try using vivard on ultimate boot cd to fix it
Oct 27, 2013 | Buffalo Technology Buffalo MiniStation...
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Driver for HD-PNTU3
This drive showing as not supported for Linux as you mentioned.
Usually this is due to the board inside the enclosure.
You could crack open the case and mount the drive internally which would resolve this issue.
Otherwise you are down to trying to find a driver (not made for this model) that will be recognized by your system.
regards,
Mike
Sep 25, 2012 | Buffalo Technology Buffalo - Hdpnt500u3s -...
My external hard drive (BUFFALO HD-PE320U2) is not working. When I plug it on the computer "safely remove hardware button" display on taskbar but no partition display on My Computer. What will...
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
Please email me at duokeystrings@yahoo.ca if you can answer the following: 1.How do I connect internal quantum fireball lct 20 3.5" 40.0 GB externally? 2. Is there a patch cord that will connect from...
this link will show you the only device you will ever need. you can conect any size hard driv or any type hadrdrive to your PC. i use this constantly and its wonderful. also it is on sale for 19 bucks so you would get it 10 bucks cheaper then i paid for mine.
Vantec CB-Isatau2
VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002&cm_re=vantec_sata-_-12-232-002-_-Product
one other thing, Newegg is a trusted site. i have dealt with them for years. if you get a bad part they will stand behind it.
Feb 05, 2011 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Please advice! I accidentally plug my Buffalo external drive of 100V to a 220V! Does this have an internal fuse? Kindly advice, my data stored are important. Thank you.
MY BUFFALO HARD DRIVE model hd-HC320U2-us WILL NOT LOAD WHEN CONNECTED TO MY LAP OR DESK TOP WILL I BE ABLE TO GET MY INFORMATION OFF THE HARD DRIVE, IS THE INFO GONE! WHAT COULD BE THE PROBLEM POWER LIGHT COMES ON BUT THE ACCESS LIGHT DOES NOT BLINK............ TO SHOW CONNECTION HAPPENING
Nov 30, 2010 | Buffalo Technology DriveStation ...
Buffalo Technology MiniStation Turbo 120 GB USB Hard Drive Logo
52 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
