Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
