Question about Sharp LC20AV6U 20 in. EDTV-Ready LCD Television
Hi, I've got a LC20AV6U Sharp LCD Television. The unit worked fine until I was disconnecting the cable F connector and evidently twisted off the RF connector... Is this worthy of repair??? Thanks. Bob
  • Sharp Master
  • 736 Answers
It isn't worth repairing because there are work arounds. You can check with your local tv repair man to see how much he will charge to solder on an rf connector for you. However you can get a set top box of some sort and connect it to this television with either an RCA cable, component cable, or hdmi cable. If you receive over the air broadcasting you can connect a converter box to this television.
Posted on Jan 03, 2011
Left speaker in my 1998 chevy s10 fades out then dies
What have you tried?
Is this an aftermarket sound system?
It could be a fault in the head unit, the cables or the speaker itself.
Assuming that its and aftermarket head unit using original wires this is what I would do:
Remove the head unit to gain access the wiring behind.
Most units have the wiring colour coded and a generally in pairs for +ve and -ve, some even have them label LR (Left Rear) RR (Right Rear) LF (Left Front) RF (Right Front).
The wires are commonly joined to the existing speaker wires by insulated electrical "connectors" that simply pull apart, though only pull on the connector NOT the wire.
Half-way jobs are just the bared wired "twisted" around the joining wire and wrapped in electrical tape.
Ensure all the connectors are still in tact and
Test after removing each pair of speaker wire to which speaker is disconnected.
When you determine which wire is for which, switch the non-working left speaker over with a working one and test to see if the speaker still fades.
1. If it does not fade then your problem is the head unit - I would replace it.
2. If it does then the problem is in the speaker or the wiring.
Remove the speaker and swap with one of your working speakers.
A. If it still fades then the problem is in your wiring and you will need to run new wires.
B. If it does not fade then the problem is simply your speaker.
Hope that helps.
Apr 09, 2014 | Pyle Car Audio & Video
LC 20AV6U manual
I think you will find no paper manuals exist and only authorized service centers have access to online info for this brand---a 20 inch set is unlikely if even a few years old to have anything but circuit boards available.
If you comment here with what is wrong I am willing to try to help you.
May 21, 2012 | Sharp LC20AV6U 20 in. EDTV-Ready LCD...
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a 32'' Akai LCD Television with a sound problem. If I hook up cable through the RF input I get a great deal of sound static and clicking noises. If I hook the cable up through the HDMI input the...
The unit will need to have the tuner module replaced. In some cases you can get the board that you need from www.shopjimmy.com Swapping a board out is not complex so you may want to do that yourself. Otherwise the unit will need to be repaired by a technician.
May 04, 2010 | Akai LCT3285TA 32 in. LCD Television
No sound from my AVOL tv
U have to use the Connector labeled RF-1 U have to screw the connector on. I had the same problem
Jul 11, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC46D64U
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
Jan 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My tv shuts off by its self then wont restart until it is unpluged for a while then it shuts off again.
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Dec 26, 2007 | Sharp LC-42D64U 42 in. LCD HDTV
Sharp LC20AV6U 20 in. EDTV-Ready LCD Television Logo
131 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
