Question about Refrigerators
Does the above model have a 240vac fuse - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Jan 03, 2011
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
What internal fuses for goodmans st101ss microwave
the modern microwaves has 2 fuses lines fuse+thermal fuse. You must see the diagram or instr. manual section troubleshooting for indication for specification of fuses. Lines fuses has 240vac and 20amps. Thermal fuses you must see the instr. manual
Jan 24, 2013 | Whirlpool GH8155XM Microwave Oven
All of the fuses check out element is good all conections good but no heat
There are 5 switch-like elements in series with the heater element, according to one diagram I found (Google "kenmore 80 dryer wiring diagram"). If any of these is open you won't get heat. If you're handy with a VOM, it's any easy problem to track down. Start at the element -- you should see 240VAC across it. If you do, the element is bad. If you don't, check across all the other switch-like things. You should read 0VAC across each of them if they're closed (good) or open (bad). It's a relatively easy matter to find a single open element, slightly more complicated if there are several.
Or, start across the 2 240VAC line legs. You should read 240VAC; if not, your problem is outside the dryer (circuit breakers DO fail). If so, there is an open somewhere in the circuit preventing current flow. Move one of your VOM test leads through the circuit from that 240VAC leg all the way around to the other leg. It will continue to show 240VAC until you pass over the open element (a switch-thing, a bad piece of wire (unlikely), or the heater element), at which time it will show 0VAC. When that happens, the problem is in the element you just passed over. If you're lucky, it will be an easily-replaced part.
Sep 23, 2012 | Kenmore 80 Series Heating Element -...
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
Does this heater need to run on 220
Electrical connections :
The heater is shipped from the factory wired for use with 240VAC, 60 Hz field power supply. To convert the
heater to 120VAC, 60 Hz operation remove the 240VAC voltage selector jumper from the ignition control board
and replace it with the 120VAC jumper. These jumpers are tie-wrapped together and are located on the fuse
board.
Feb 16, 2011 | Hayward 400FDP Universal Series Low Nox...
I have a power source but I not sure if it belongs to an HP Scanjet 4200c Its features are: 230v 50 Hz 21 W 16V 1000mA 13VA is appropriate? Thanks
Line Voltage 100-120VAC 60Hz
100-240VAC 50-60Hz
200-240VAC 50-60Hz
I read the above at the hp.com website on the electrical specifications section of the specifications page.
Feb 04, 2011 | HP Scanjet 4200c Flatbed Scanner
The dryer does not start. There are no lights on
did you plug something else into the outlet to make sure it's not the house fuse,if the fuse is good check the back of dryer where the plug wires connect to the dryer and read it out with ameter to see if power is going to the dryer,next time send model number,let me know what you find
Feb 21, 2010 | Kenmore 63942 Dryer
Dryer runs, but no heat. Is there a heating
No heat is not always an element. It could be the thermal fuse (check this first), a thermostat or a leg of your 240VAC missing. Replacing an element is relatively easy depending on ones mechanical abilities. Depending on the model it is accessable from either the front or the back. Back one is easiest.
Eric
Oct 12, 2009 | Kenmore 62602 Electric Dryer
Blown fuse
You can purchase it in any electronics shop, just tell them the rating Ex. 3Amp/240Vac you can see this rating at the cap of fuse.
Jun 02, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
