Question about LG WM2277H Front Load Washer
Mold in the seal around the door. Bad musty oder from towels.Very disapointed with this washer.
  • 4 Answers
The mold is coming from too much soap. You have to use HE soap. I know this sounds funny but it's true. I started using less soap as specified by LG after I rinsed the system with water and vinegar a couple of times. But the vinegar in the bleach compartment. I may take a few times to clean the system out but the smell will go away and with continued use of HE soap in small amounts the mold will not return. I never knew mold likes soap scum. Good luck. Give me a thumbs up if this worked for you. :-)
Posted on Jan 06, 2011
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
There is a musty oder coming from inside washing machine.
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
Good Luck
Aug 08, 2009 | General Electric WBVH6240HWW Front Load...
My towels smell musty and I have used he washer cleaner
this smell is very commun with this washers but is unexeptable therefore is an attorny helping with issue.
Please read this web side contact them and please let me know the results.
http://www.lawyerseek.com/Practice/Consumer-Protection-C21/Whirlpool-Duet-Mold-Problems-P172/
Your rating and VOTE is very important to me....
I hope this information was helpful?
I like to tank you for the oportunity you give me to serve you.
please if you have any question or concer please e-mail me, I will be more then happy to assist you.
Sincerely
vickygomar
Jul 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Elite washer has a musty odor. I have run an
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
Jul 24, 2008 | Maytag Washing Machines
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277H Front Load Washer Logo
270 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
