Question about Ruud Heating & Cooling
I have a Rudd deluxe 90 plus mod.uged-06emaes. The unit high limits and restarts immediately after total shutdown. (takes about 2 minutes after burner is shut down) The burner operates for 5 minutes only. Airflow problem? This install is in a duplex and both furnaces do the same thing!
  • mikejwillis Jan 03, 2011
    The ductwork and blower are clean now. would you recommend removing the blower assembly to clean heat exchanger from below?
    Both units worked very well for years so I believe the ducts are sized properly. Dust has been a problem for a long time. (poor housekeeping combined with infrequent filter changes) I'm a little timid about disconnecting the circuit board as I know they can be fragil at this age. Maybe I can swing it up out of the way in order to remove the blower?
  • 43,501 Answers
Yes air flow or gas pressure adjustment... too high...
heatman101
Posted on Jan 03, 2011
Testimonial: "You were right on! Keep up the good work and many thanks to this forum that I stumbled upon! I'll be back again I'm sure as I love to DIY"
  • 1 more comment
  • D. Floyd Kolb
    D. Floyd Kolb Jan 03, 2011
    Yes, I would at least check that.... but is the ductwork sized correctly...???
  • D. Floyd Kolb
    Okay... it's becoming clearer now....yes, the coils are probably filled with dirt, but also check the fins of the blower wheels while you have them out...they can fill with **** and then not move the proper amount of air...
    Usually you can get enough wire to just move the boards out of the way... the blower will also start to drop down as you start to pull it out of the slides...the two screws that hold the blower in can also be a bugger sometimes...it can take a lot of patience to get the blower out of there....and getting it back in.... well that's another story....have fun!!! The good news is that you just need to stay calm and be patient and it will all go together again....:-)
  • mikejwillis Jan 08, 2011
    Thank You heatman101!!! You get my vote. After all the tech work, it was clear what needed to be done. I found the secondary exchanger to be 100% clogged!! Just finished cleaning the one in the other unit. (remember it's a duplex) It was 33% clogged!! I had it cleaned a "few" years ago after it broke down and paid dearly for the nice guy that did the work. People!!!! Things that move air need to be cleaned ever so often. I see post after post of furnaces that cycle on and off like mine did...... CLEAN THEM!!!! Thanks again for giving me the "courage" to do it myself.......wasn't so bad at all. Mike
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
Just bought a rudd 80 deluxe plus and need to know how to hook it up to power
If this is split or package unit, you're also going to need a Tstat wiring among other things. If you can do that, then connecting power is a cinch. Don't burn the house down, call a professional.
Aug 30, 2013 | Heating & Cooling
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
Compressor cuts out after 20 minutes then restarts after maybe 20 minutes
This is usually due to low limit or high limit cut off switches. Basically when it's low on refrigerant the unit cuts out to protect the compressor. Then after 20 minutes the pressure equalizes and the unit kick back on, or the opposite for the high limit switch.
Feb 10, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
My Kenmore Dryer 90 Plus Type DDOTELE2406028-EH54 Mod 11068942892 runs but does not heat.
The common problem in this case is in the high-limit thermostat and the thermal cut-off located on the heater housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat by removing the bottom front panel.
Removing Bottom Front Panel
Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Let us know should you need further assistance.
Dec 21, 2010 | Dryers
Wont trun on standby flashes 7 times then restarts
hello. High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Oct 20, 2009 | Sony KP-51WS520 51" Rear Projection...
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
Heating & Cooling Logo
220 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
