I,am getting cold air than warm/s up a bit than goes tocold again the temp gage stays at 90 maybe thermaste or could be sensor .gave me an answer please thank you. Jules
    Genius:
  • 1,015 Answers
Take cover off of your thermostat,it should just snap on and see if your stat has a mercury switch in it. It will be a small glass vial with a small amount of mercury in it. Check to see if t-stat is level if not then loosen mounting screws and level stat then retighten mounting screws.If the mercury switch is very far out of level it will never read close to actual setting. Thank you
Posted on Jan 03, 2011
Heat is not acting right
If you checked properly and coolant/rad isn't getting hot, coolant is up to proper level, then I'd replace thermostat.
Feb 12, 2014 | 2002 Chrysler Town & Country
Temperature gage fluctuates when driving my 1996 mazda protege
Well sounds like first start your car record where the temp needle reads, then let the engine warm up (with out driving) then rev the engine to about 3500-4000rpm a couple times does your needle move at all record then hold your rpm at 3500 for about 5-10 sec does this get the gauge to drop? sounds like you may "if not over heating at all and coolant level and circulation is good" have a circuit problem, you can test this by going to auto zone and ask for a scan to be done on your car when the plug into your OBD 2 ask them to go into DATA STREAM and then check to see what temp your ECM thinks the engine coolant is at does it match your gauge at idle and at 3500rpm if not its a faulty circuit
Jan 15, 2012 | 1996 Mazda Protege
Replaced thermostat and sending unit .check engine light went out .on incline have 3/4 gage warm, when level goes 1/4 on gage cold air,temp wont get hot.or 1/4 gage.could this be computer if so how to...
Not computer. You have air in the cooling system. Bubble is moving around. Park on an upward incline, take the radiator cap off, run the engine and keep the radiator full. Let it warm up and let the thermostat open (until you see flow in the radiator). Then fill to the brim and keep full until it stops going down. Also open any bleed ports you can find in the cooling system (there may not be any) and let any air out of them. Let the engine run and check for any bubbles that continue to come out. If bubbles continue to come up, you have a blown head gasket that is forming the bubble and causing the heater and temp gage issues. If bubbles do not come out, maybe you have fixed the problem by getting all the air out. Please let me know if you have any questions.
Dec 06, 2010 | 2001 Chevrolet Venture
I have a 1993 Acura Ledgend. For some reason my heater does not continue to blow hot air, it does for a few minutes and then begain to blow cold air. It does this often now. It works and then it blows cold...
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Nov 30, 2009 | 1993 Acura Legend
Temp gage normal warms up and then goes red for a few seconds
is the thermostat sticking from cold operation?
have you tried replacing it to see if it still happens?
if it does still happen, could be temperature sensor
the sensor might be cheaper and easier to replace 1st
Nov 03, 2009 | 2004 Ford Explorer
Temp Gage
sounds pretty normal. its not overheating but if you still want to do anything try replacing the thermostat and see it it changes
Jan 28, 2009 | 1991 Mazda Protege
Caravan 1994 (3.0 Liter engine) No heat
U have a problem with the air temp control blend door actuator motor, very common failure. In order to replace this part the dash must come out.
Jan 14, 2009 | 1994 Dodge Caravan
1997 Chevy Cavalier Z24 2.4l
did you check the gauge that could be bad and did you check the thermostat thaat could need replacing
Aug 02, 2008 | 1994 Chevrolet Beretta
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
