Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
I have a problem with my HP 8500 where it is always jamming or indicating there's a paper jam when there isn't one. The rollers are very noisy. It has been a problem from the first, but is now impossible to print at all. It is a year old.
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Jan 03, 2011
Xerox phaser 8500 paper jam
Before you clear the paper out, If you press the question mark button (?) it will display the Jam Code which will narrow down what kind of jam you have. You can look it up if you can get access to a service manual.
Oddly, the most common jams aren't caused by rollers and need a DM camshaft 020K14801 changed instead. If you have jams right at the tray then get the roller kit 604K42200 after all.
Good luck ...Whit at www.iteminconline.com
Aug 18, 2013 | Xerox Phaser 8500/DN Printer
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
HP Officejet 8500 says "Paper
There is definitely a paper jam. It's up to you to find it. Sometimes it's a very small piece of paper. I have worked with these printers before. If it says paper jam, that means there is a paper jam. Look a little bit more closely. I garranty you 100% there is a paperjam.
Dec 08, 2010 | HP Office Equipment & Supplies
Always paper jam. need solution
hello, the first thing i would recommend you to do is listen to machine, if you hear the machine clicking, the sound is rythmic, sorry, it does not carry a beat, but the noise is not normal, if you do hear the noise then yes your printer is broken. if you have lower tray, check to see if your jamming from that tray, you can clean both feed rollers for both trays, and try again, if document feed jam, check to see if something tore in the paper guide.
Sep 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper Jam HP OfficeJet 8500
etechrepair.jpg Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
Mar 28, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Not feeding paper very noisy whin it tries shoes to be jammed
You could have a paper jam that's jamming the gears that turn to feed the paper. Make sure there's no paper inside jamming up the roller bar. The other possibility is that you have a stripped gear, that is chattering when it tried to drive the paper feed roller.
http://welcome.hp.com/country/us/en/support.html
Make sure you get an estimate if you get it repaired, since the cost of repair can often justify just going ahead and buying a new one.
Good luck, and hope this helps.
Jan 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
