Question about Garmin eTrex Vista Cx GPS Receiver
When I power up my eTrex Vista, I get the initial screen with the Garmin eTrex logo & then nothing else displays on the screen. It sits there for hours. I can't get any other menus or screens so I can't adjust any settings. Curiously, it will display the menu saying that it can't acquire the satellites. The menu is the one that says "continue searching, use with GPS off, use map, etc.). I can select any of those options but then it returns to the Garmin logo and nothing else. I used the updater to reload the software (computer detected it and displayed the model id) and nothing changed. Repeated all of this with and without batteries. Any suggestions?
SOURCE: Garmin eTrex Legend
If it hasn't been used in a long time it could take up to 30 minutes to get positioning. Get a clear view of the sky and let it set at least 30 minutes. If that doesn't work antennae connection is bad. Its not a software issue.
Posted on Nov 23, 2007
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
  • 6 Answers
SOURCE: GPS displays BNG on location
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Posted on Jun 24, 2008
SOURCE: Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Posted on Dec 07, 2008
  • 98 Answers
SOURCE: want to download free maps to my garmin c550 gps
hear is the manual what maps do you want
Posted on Jan 25, 2009
My 3 year old Garmin Etrex Vista just started displaying horizontal lines across the entire display. Any suggestions?
Try updating the unit's software via the Garmin.com website. This may fix it as there was a satellite launched which was causing problems with some Garmin units.
Sep 25, 2009 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Vista HCx searches for satellites but doesn't find any, since yesterday. Device has worked fine for a few years, has the latest firmware
I have the same problem. Satellite screen shows nothing except the rings. When I open the unit, one of the chip looks like broken; its label says K43 and V5.
Aug 09, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Etrex Vista HCx will not calculate routes.
Please post the co-ordinate of the starting waypoint and I'll check it with mine.
Aug 12, 2008 | Garmin eTrex GPS Receiver
Etrex - can't find satellites anymore. Just stopped one day after downloading Points to my pc
To my knowledge, a reset on a Garmin eTrex would require:
Holding down the PAGE and PAGE UP buttons while simultaneously powering the unit. The Garmin eTrex will enter the service mode/display:
- Bravo Version
- Software Version
- Time
- Internal temperature of unit
- Battery voltage
- External voltage
- Button presses
- Other tech info
You can also perform an LCD display/screen check by pressing the PAGE button 2X.
A firendly word of advice: While entering the service mode is interesting and useful, be careful which buttons you press because it is also possible to rest the unit to factory settings within this mode. Pressing "up"+"enter"+"on/off" keys in service mode will reset the eTrex to factory defaults. All presets and data will be lost.
To exit just turn it off as normal, and then turn it back on as normal. Unless you deliberately reset the GPS, nothing should have changed.
Alternately, you can try: Hold down the find, click-stick, and page buttons. Press the power button, and when the title screen appears, release the buttons. This will clear all memory (you will lose all waypoints, etc. back them up first).
Find button: bottom button on the left
Click stick: the button on the face of the unit
Page: the top button on the right
Power: the bottom button on the right
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 26, 2008 | Garmin eTrex GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Garmin eTrex Summit Screen
see discussion at http://californication.mtbguru.com/2005/11/20/deconstructing-the-garmin-etrex-vista/ Its possible that there's a bad connection at the ribbon cable, but most likely its a bad connection at the edge of the LCD glass panel. I've had two eTrex fail because of this problem. Don't pay the riduculous price Garmin asks for repair - just buy a new Magellan unit. If you must get a Garmin, go with the high-sensitivity receiver.
Sep 25, 2007 | Garmin eTrex Summit GPS Receiver
Garmin etrex handheld
There's really nothing to setup, you just mark waypoints and it displays them on the map. If you press enter on any screen, it will give you options for that screen.
Jul 30, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex Vista Cx GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
