Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Where is the filter located in the refrigerator?
    Problem Solver:
  • 8 Answers
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Posted on Jan 03, 2011
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Where is the air filter located on the model ARS8267BC?
There is no air filter on your model refrigerator or any other model that I know of, Sea Breeze
Mar 27, 2013 | Amana 12488101 Refrigerator Air Filter
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
Cannot locate water filter
From my experience the water filters for most refrigerator are near in the area of the Ice maker cubical.
Jul 16, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
204 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
