Question about LG DU-37LZ30 37 in. LCD HDTV
If it is the power supply are they available, and if yes where from?
  • 6 more comments
  • john enyeart Jan 04, 2011
    The Board is a KN Powertek KNP-3800 rev 9.0 2004-08-12. The Part Number is PN5531B283B0781. Is there a way to figure out if it's the power supply or one of the other boards. I unplugged all connectors and put them back on one at a time, when I plugged in one connector to the biggest board the light started flashing green then when I plugged in the other connector it went back to green and red alternating light.
    It continually alternates red and green at about 120 cycles per minute, give or take.
  • john enyeart Jan 06, 2011
    Thank you Sai. I am having trouble with the terms used in the service manual, like D_board. I don't know if they mean the digital board or the DVI board. Not that I know a lot about those boards anyway. And I never managed to find that power supply on line. I found the power supply just that they are no longer available. But your help was very good I'm just going to have to try and cipher through it. Thanks again.
    I'm having to do a little guessing, the 6vdc I'm suppose to see in the second step for standby voltage on the digital board fluctuates from .8vdc to 4.9vdc, so I consider this a fail. So I check my reference voltage at CN304 which on this power supply is CN804 pin 15, looking for 24vdc, don't even have 1vdc. So condemn the power supply? I went on as if it passed at 6vdc and had the same result for the A_board. What do you think? Every step I've tried fails so I'm thinking, with the fluctuations I'm seeing in the voltage, that one of the ac buffering capacitors on the power board has failed letting ac voltage through to the dc side. I could be way off base because I'm not trained in electronics. But I have seen something similar on a power supply for an MCS panel on a compressor package I used to take care back in my youth. I could actually measure ac voltage coming out of the power supply on the dc side. I learned how much was acceptable before I would replace the capacitor and the problem would be solved. Just a thought.
    That's the right part number. I found that it was out of stock everywhere I looked online. Of course I was using the K N Power tek part number, still I had the same result, and I don't know where else to look. Thanks for your help. if you can find it I would really appreciate it.
    I went there immediately and tried to place an order they said they were out of stock. Is there hope for any where else? Thanks
  • john enyeart Jan 07, 2011
    Thanks for all your help I let you know how I do.
  • john enyeart Jan 08, 2011
    No luck, no longer available even through LG. I guess I'll have to try and find somebody who can repair the old power board, or breakdown and go new.
  • 4,889 Answers
You can find them on shopjimmy.com. If you can just get me the part number off the board, I can find you a replacement.
Sai.
Posted on Jan 03, 2011
  • 4 more comments
  • eagle338
    eagle338 Jan 04, 2011
    Ok. What is the status of the LED infront of the tv? DOes it blink(if yes then how many times does it blink in between each pause?) or does it just stay on?
  • eagle338
    Ok. I do not want to take a guess as to which board it is. So lets test it to be 100% sure. I have uploaded the service manual for you. The test points are in the flowchart on page 14.
    http://www.mediafire.com/?inec1754h4j4mq...
    It has even comprehensive details at what pin of a particular IC you have to test. Voltages are to be measured with a multimeter between the specified pin and ground. Give it a shot and let me know what you have found. If you have any questions regarding the testing procedure, please let me know.
    Sai.
  • eagle338
    eagle338 Jan 06, 2011
    Since you are seeing voltage drops at every point, I believe it is the power board. It does not look like a capacitor issue to me(unless you find any capacitors that are bulged/cracked at the top). It looks more like a short protect error, which can make the repair far more complicated as the schematics are not that good. Also the part number you have quoted sounds more like a serial number. The part nimber starts with 6. The part below is what I found in the service manual: 6871TPT283B. Verify this against the part number in your set. Ofcourse it is out of stock, but we can always look for it un other places if you can get me the part number
    http://www.shopjimmy.com/lg-6871tpt283b-...
  • eagle338
  • eagle338
    I am afraid you have to source it from LG. You have a better chance of spotting a UFO than finding it online. Call them at 1 (800) 243-0000
  • eagle338
    eagle338 Jan 08, 2011
    Well ofcourse you can find people to repair it. Our repair directory might be of help to you.
    http://www.fixya.com/Repair
No power to starter starter is good
Confirm power is availible at starter main power supply, step one , using mutl meter check for 12 volts at battery positive terminal , 2, check main voltage supply lead to starter from battery pos post , 12 volts present? yer check voltage supply lead from battery pos post to altenater , then to starter , 12 volts present, yes , check small wire to starter at starter for switched 12 volts present yes change stater after confirming suitable ground, no, trouble shoot ignition / starter switch in colume
Mar 08, 2013 | 1999 Land Rover Range Rover
No audio or video flashing 2 power 1 opc after relay latch?
Yes,this problem are related to the main Tuner signal board,must change the main Tuner signal board,to solved this problem.Put back your old power supply board too might be still good,but some time the power supply board must have to be replace too,becaused it got corrupted by the data from the main CPU from the main Tuner signal board.
Feb 20, 2013 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Does cdi affect ignition in pulsar 150
yes the cdi is most importing.the starter coil supply electricity to cdi then cdi forward electricity to high tension coil,and high tension coil forward the electricity to spark plug,spark plug give more fire to piston.cdi not only supply only electricity,cdi adjust the electricity and control the power.ok?
Sep 13, 2011 | 2005 Bajaj Pulsar 150
I have a Westinghouse lvm 37w1 tv and it keeps turning itself off sometimes it will let me turn. it back on and sometimes I have to wait a few minutes do I need to buy a new tv can I fix this myself
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help to solve the problem....
May 10, 2011 | Televison & Video
I need a power supply/ volume , and bass control for creativbe labs t2900 speakers. can I purchase one?
Hi, Yes you can purchase the power supply and base control for you creative product. You can go to the website www.buy.com or you can select the below link to go to the webpage directly. http://www.buy.com/retail/usersearchresults.asp?querytype=home&qu=Creative+Labs+Inspire+T2900+power+supply&qxt=home&display=col&cb=422451212
You just need to type in as what you want in the search box and then select from the categories available. Free shipping is also available.
Hope it Helps. Regards Anand Sachan
Nov 06, 2010 | Creative Labs Inspire T2900 Computer...
How to install a 2nd sata disk drive - do I need a 2nd sata cable?
Yes you need one SATA cable for each SATA device.
Biggest thing is to make sure that your motherboard has enough SATA ports available to accomidate another SATA device
Sep 27, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Overseas Use
Yes. The power supplies and battery chargers supplied with all Powershot Digital Cameras are designed to work on input voltages from 100-240 volts (50/60 Hz). The only item that you may need is a plug adapter that allows you to plug the U.S. type power supply or battery charger into the foreign type wall outlet. Plug adapters should be easily available at a local electronics store.
Aug 31, 2005 | Canon PowerShot S10 Digital Camera
LG DU-37LZ30 37 in. LCD HDTV Logo
622 people viewed this question
Computer Repairing
Computer Repairing
