How do I open the door of the ASKO ASEA 12003 washing machine. I have a washed load in the machine
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
  • 1294 Answers
SOURCE: asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
Posted on May 10, 2008
  • 417 Answers
SOURCE: asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Posted on Oct 13, 2008
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I don't have a manual for asko asea 12002 front loading washing machine and cannot find one on line.
I have tried my own FixYa advice which I offer to all and with similar success!!!
I would email mailto:info@askousa.com and ask them. Sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
Door wont open and wont turn on
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 18, 2011 | Asko W6021 Front Load Washer
Hi - I have the Askko asea 12002 and the machine won't empty water and therefore door won't open. How do I get around this. I need to get the clothes out ASAP.
Remove outlet hose at back of machine and drain into a bowel or bucket the door will then open. Check your filter is not blocked and also the pump
Jul 29, 2010 | Asko Washing Machines
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko front load washing machine
May 09, 2008 | Asko W6021 Front Load Washer
Apr 02, 2008 | Asko Washing Machines
Jun 11, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
