Question about JCPenney Televison & Video
Jcpenney RGB stero monitor/reciver has green grey picture with lines scrolling the screen,sound works fine idk what it could be its and older model #685-220
  • 81 Answers
SOURCE: green screen&no picture only sound
check the crt socket could be a bad solder
Posted on Dec 13, 2006
snakehead
  • 1074 Answers
SOURCE: Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Posted on Apr 27, 2007
  • 1153 Answers
SOURCE: Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Posted on Sep 14, 2007
fanicate
  • 60 Answers
SOURCE: LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
try your monitor to other computer or try other monitor to your computer to see where is the problem
Posted on Dec 10, 2008
SOURCE: onkyo ht-557; picture dropped out, now just green screen
don´t you activate the progressive scan by mistake
Posted on Apr 23, 2009
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
What is the cause and is there a fix for the two vertical lines in the center of my LG monitor.
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 11, 2014 | LG M4225CCBA 42 LCD TV
Sound ok both dvd and sky input picture grey pixilated
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 08, 2017 | JVC LT-37X688 37 in. LCD HDTV
Screen just turned green. Sound but no picture.
Contact your LG repair centre. There will be a problem with the main board settings for the RGB gain levels, this is the area which sets up the colour balance. A factory re-set may cure the problem but more likely the EPROM settings on the main board would need to be rectified.
Nov 29, 2009 | LG Televison & Video
NO PICTURE
There's an internal electronic parts of your HDTV that are cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose and fix it. best regards
May 22, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top JCPenney Televison & Video Experts
Are you a JCPenney Televison and Video Expert? Answer questions, earn points and help others
