Question about Sport & Outdoor - Others
The plastic shield on the front of the treadmill holding the tread in place broke in a move. It's screwed in on both sides by a couple of screws.What part would this be and is it available to buy and fix myself?
    President:
  • 1,082 Answers
Contact manufacturer for parts.
Try google "manufacturername".com or consult your manual for contact info.
Posted on Jan 03, 2011
How to remove car door panel
The door panel is held in place by 2-6 screws and several clips. Remove the screw from the handle and lever under the plastic caps. The speaker may be secured to the door with 3 screws (this varies per vehicle). The is a small plastic cover near the side mirror that must be removed with care. It pulls straight out, but the metal clip in the plastic may need help from a flat blade screwdriver.
There are several screws that hold the plastic rain shield in place. Remove the rain shield carefully.
Additionally, there are several videos on YouTube that demonstrate the process. The last one I viewed missed the screws in the door in my 2001 Odyssey.
Aug 07, 2014 | 2003 Honda Odyssey
How to open the box of the treadmill
You have to lift up the back of the treadmill a little to access 2 phillips head screws that keep the motor cover on, (note that you will also have to unscrew a few phillips head screws on the bottom front of the cover as well in order to remove it completely). Before you begin lifting the back of the treadmill platform off the ground to access the screws underneath make sure the treadmill is on a zero incline setting and it helps to find a sturdy object you can rest the tail end off the treadmill on about 1 to 2 feet above the ground giving you enough room to access the screws underneath. Another option is to lift the treadmill platform all the way up and lock it in an upright position using the locking mechanism and lock handle that is located underneath the machine. I find this route to be unnecessary and cumbersome for what you want to do. Once you lift the treadmill up you will see the 2 small Phillips head screws near the front of the treadmill running platform that you need to unscrew in order to take off the motor cover. You also need to unscrew a couple small screws under the machine located on each side of the wood running board. These screw fasten the top inner plastic side covers onto the top of the running platform which needs to be taken off in order to access the back rollers. Make sure you collect the screws in a way that you will remember where they go later when you reassemble as this is your first time taking them out and you might forget later. Now with the bottom screws out, lower the back of the treadmill down level on the ground and pull off the motor cover, and the Left and Right INNER plastic running platform covers. With the inner covers removed you will find yet another small set of screws fasting the main plastic side covers to the running board which require an allen wrench to unscrew. Use the small wrench that came with the machine if you have it handy. With those off you can pull the main Left and Right plastic running board covers off, just make sure to carefully unsnap them from their snap points near the bottom rear of the machine. With all the covers removed you can now access the bolts that hold your treadmill rollers in place and the drive belt which you will have to slip on and off the motors drive pulley and the front roller using a pull and turn technique. The back rollers are simple and can be removed by unscrewing the tension bolts at the back of the treadmill and pulling the roller through and out of the belt. With drive belt set aside and all roller bolts removed you can take out the front roller in the same way you removed the back roller. Replace the treadmill belt and reassemble the machines components in the reverse fashion you disassembled them using these instructions. Doing this yourself will save you hundreds of dollars service man visits in the future.
Jun 27, 2014 | Epic View 550 Treadmill
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
Pro-Form 585Tl Treadmill
Either a wider diameter self tapping screw, or a screw with a washer and a bolt on back if you can reach the other side of the frame to get a nut on it. If nothing else works they have a variety of "mollys" at home depot. you may be able to tap a lead molly in and get the screw to hold that way, and last but not least, if it's just stripped, try filling the hole with epoxy and inseting the scre in through it. If I remember these are mostly plastic so be careful not to torque down which ever way you decide to go. Without having the treadmill in front of me I am giving you generic fixes that you can analyze and see if they will work for you. I don't know if a nut is going to fit in the space alloted for the screw although that is the bes idea. If its a stagnent part, it shoudn't matter. If it has to revolve then don't use epoxy. good luck, I have fixed enough tread mills to fill a warehouse and they are all a little different, usually anything that folds will have a problem eventually no matter how careful you are.
May 19, 2010 | Proform Exercise & Fitness
Ironman Triad motor cover will not come off
To remove the motor cover (#19 from parts list), you have to remove the follow items first:
- Left and right fenders (#20 and #21 from parts list)
- Left and right sideboard covers (#49 and #50 from parts list)
There are 4 screws holding the cover - 2 at the front and 1 on each side. Be careful when you lift the cover, the circuit breaker cable is attached to the cover.
Finally, you may want to reconsider doing that. There is nothing under the cover that requires maintenance. The big *** motor is driving the front tread roller through a belt. The roller has sealed bearings that do not require oil.
Feb 19, 2010 | Ironman Exercise & Fitness
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Treadmill adjustment on bowflex 5000tc
There are two hexagonal screws on either side of the front rollers, and four inset hexagonal screws on the back rollers. Turn it on the lowest speed while turning the ones in front, one at a time. You'll see the tread move from one side to the other. Tightening the screws bring the rollers out, pulling the rubber tread taught, and to the left or right, depending on which screw you're turning at the time. The treads should roughly be the same tension, adjusting both inside and outside front screws for each tread. If you have the dual rear rollers, you'd then have to stop the machine after finishing the fronts and tighten the four inset hexagonal screws on each of the rear rollers. No adjustment per se, just tighten them. If you don't, you'll have a sort of clunking, or clicking noise from the imbalance. The single rear roller is a little different, and the adjustment I believe, can be found on this site:
http://nautilus-technics.com/
Good luck.
Dec 28, 2008 | Bowflex Treadclimber
Sport & Outdoor - Others Logo
47 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
