Question about Cuisinart DCC-2000
Water will not flow from water basin to coffee drip. Only will get 2 cups, and stop & then I have to restart the on/off to get flow again. Changed the charcoal filter, but not sure what else to check in the water flow.
  • 8,596 Answers
Try the vingar/water cleaning first.
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
I have an older model cuisinart 12 cup coffee maker. This am the water will only slow drip through the filter. There is lots of gurgling but not much coffee. Can u help me figure out what's wrong?
Calcium buildup. Follow your coffee maker's manual cleaning procedures to dissolve the hardness buildup.
If you can't find your manual, try mixing 1-2 cup of white vinegar in an 8-oz to 12-oz pot of water and pour it into the water receptor. Run the coffee maker until about 1/2 the water has passed through the machine then turn it off and let it stand for awhile (say an hour). Then turn it back on and let it finish. This should dissolve the hardness buildup in the machine and restore the flow. If not repeat. If you use a paper filter during the process, you should capture all sorts of hardness particles.
After it's flowing good again, run with one or two pots of water to rinse.
Oct 23, 2016 | Cuisinart Coffee Makers & Espresso...
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
My keurig is brewing only alittle coffee and the rest of the water is being poured back into the water basin, at a very hot temp.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. However, I've not heard of your particular problem with it running the heated water back into the basin. Try cleaning it & see if that reduces or eliminates your problem. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected). If this eliminates your problem, it should be done every 2-3 mths.
If that does not work - call Keurig's Customer Service # at 1-866-901-BREW (2739) Good Luck.
Sep 06, 2011 | Coffee Makers & Espresso Machines
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
See page 4 for amount of coffee to use.
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
Water does not go through the cup
The drip spout may be clogged. Easy fix, just poke through it with something like an ice pick or even a paper clip. Also, you may be using too much coffee grinds which could slow down or stop completely the flow of water.
Dec 25, 2010 | Keurig B60 Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Aug 20, 2007 | Nespresso C190 Espresso Machine
Coffee Makers & Espresso Machines Logo
322 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
