Question about Garden
Need a manual for guardian 21230L garage door opener?
Posted on Jan 04, 2011
Testimonial: "Many thanks for help, just what I needed!"
My Guardian 21230l Door opener light is no working? I have replaced the bulb twice in 7 years, but now nothing happens. Any ideas?
Trace circuit, back through the wiring, through the switch, and back to the source, using a meter.
May 04, 2017 | Building Materials
Guardian garage door problem
check for loose or out of adjustment limit switches for the door travel
Jun 05, 2016 | Building Materials
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers
if your saying that the light on door opener housing is flashing then stopping after a few moments , this is a sign of a fault in door safety's , either the door has to much friction now to move or beam detectors have sensed a problem
Nov 13, 2015 | Building Materials
How do I remove the lens cover for the light on a Guardian garage door opener 21230L?
Not sure about the Guardian, but it should be in the installation manual which can be downloaded, if you don't have the original. On my "Linear" brand, you just have to press the plastic cover at the right place and it releases.
Aug 04, 2015 | Building Materials
Guardian garage door open will not close, it beeps 12 times
optic sensor issue most likely. check alignment, check wire for breaks, check staples shorting out wires. it you hold the wired wall button and the door closes, then it is a sensor issue. you can also just jump the terminals where the wires connect on the opener motor and see if it works normally, if so, again the sensors are the issue.
Apr 30, 2015 | Building Materials
Guardian sectional door 21230L opens & closes by itself without any one touching the remotes.
check all the wiring and be sure it is not pierced by a nail or staple
Oct 15, 2014 | Building Materials
Guardian 21230l
Sounds like you need a replacement remote.
Feb 11, 2014 | Garden
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
Garden Logo
2,392 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
