Question about Dryers
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and nothing happened. I can hear the timer making small clicking sounds.My dryer is a Kenmore 70 Series Model#96573230
    Problem Solver:
  • 8 Answers
I had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Posted on Jan 03, 2011
Dryer doesn't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Mar 07, 2015 | Dryers
Gas dryer wont light with door closed
Check the exhaust to make sure that it is not clogged.
Jul 07, 2013 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Jul 21, 2009 | Kenmore 62802 Electric Dryer
It will not heat and the timer will not shut off.
The timer naturally won't shut off till the sensors inside the drum no longer get a capacitance reading when the clothes are completely dry. The moisture control board relays power to the timer motor when it is sure the clothes is dry. The heating element could be broken.Unplug the dryer. Take the back off. Get the heater off and take a look at it. Check your vent pipe, if it has lint in it then your high limit is probably open. The fuse ain't broken because the dryer still runs. Both parts in the kit need to be replaced. because the big one is supposed to shut down at 250F the little one(high limit) mounts in the upper heater housing and gives up the ghost when the temp reachs 300F. The fuse mounted on the blower housing is rated to die at 350F. It is tied into the door safety switch, when it dies it is the same as if you opened the door. The dryer will not run. BTW: if you ain't got the $ to get a new limit you can reset it by banging it on the floor in a fit of rage. LOL
Feb 07, 2009 | Kenmore 63942 Dryer
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Sears Kenmore Dryer #86681100
I took the top off of the dryer to access the door switch. Took the number off the part and went to Trible's appliance parts and got a replacement. Works fine now.
Mar 30, 2008 | Dryers
Dryers Logo
96 people viewed this question
Top Dryers Experts
