Question about xheli Double Horse 9074 3 CH RC Metal Helicopter w Gyro Flashing LED Balance
I get no signal. i have checked everything. the batteries, the on/off switch, and charging it. WTF?
    New Friend:
  • 90 Answers
Same thing happened to me i think somethings wrong with the antana in the helicopter take it to a electronic shop like redio shake or something
Posted on Jan 03, 2011
Where is fuel shut off on a 2004 dodge 5.9motor urns over good but no start ,not even with a shot of fluid
As far as I know, on US domestic vehicles, only ford has shut-off switch, inertia/bump switch.
Make sure battery has a full charge. Have helper crank it while you check for spark at the plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse. Any applicable trouble codes?
If your missing everything, I'd want to check for rpm signal?
Dec 19, 2017 | Dodge Cars & Trucks
1988 ford Taurus turn signals not working. Help? The hazard signals work. Replaced switch on column and flasher. Still no turn signals? WTF?
There are two flashers, one for the four ways and one for the turn signals. If I remember right the turn signal one is on the backside of the interior fuse box.
May 06, 2016 | Ford Cars & Trucks
Hello . i bought a used 2001 saturn s series. everything was fine , the car doesnt nstart.the battery light is on the dash board p[lus "service engine soon and oil pressure light.i already changed...
First thing you need to inspect the battery.The battery warning light is coming,due to battery is low on charge or battery got weak.If the battery is low on charge then get it recharged.But if battery is very old,then get it replaced.The battery and turn signal problem are two different problems.
Turn signals not working are due to faulty hazard switch/Turn signal switch,or faulty flasher unit.But in some cases its due to faulty turn signal fuse located in the interior fuse panel.This possibilities needs to be checked.Keep updated for further help.Thanks.Helpmech.
Jan 05, 2012 | 2002 Saturn L-Series
My 2008 hyosung gt250r will not start but i can push it off and it works great and shifts fine and the lights go dim when the bike is not running and the brake light and head lights work but the blinkers...
short in wiring or switch causing battery discharge. charge battery to full charge . see if everything works right. ifturn lights
still dont work, un hook switch to turn signals . wait for the next
day and see if your battery has held charge . should read 12v
or 11.5v . if battery stays up switch maybe shorting out. check wiring for chaffing
Oct 21, 2010 | 2005 Hyosung GT 250
Me2
3 things and 1 is serious
Not a clear view of the sky...
Batteries are too low to read a satellite signal fully charge the unit
The SIIRF chip is damaged.. Expensiive!
If you put it into car power and start engine it will damage the unit and one day you will turn it off and then on and it will never work again
Better hope its just a low battery
Please rate our help to keep FREE service online
Aug 30, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
Battery not charging new alt new volt. reg.wtf?
Ensure alternator excitation lamp (IGN) indicator lights when Ignition vehicle ignition is switched on prior to starting engine.
This light should normally extinguish as soon as motor starts.
(+12V is supplied through a small lamp to the Alternator 'IND' terminal whenever the Ignition switch is on).
Also check for any burnt out fusible link on the alternator output- terminal B+ should have battery voltage on it at all times.
Jun 12, 2009 | 1988 Lincoln Continental
The charger is not connecting with the phone to charge it, the phone is out of battery but still has a white screen and makes some noises every so often, WTF is wrong with the thing? it was working the day...
I had the same thing with a sony, so I'll tell you what I did with that hopefully it works. I cleaned the charger connection on the phone(sometimes grime gets in the slots). then switch the phone off and take out the battery and sim for at least a minute or so. Put everything back together and plug in the charger. If this doesn't work I would suggest you take it to the manufacturer or the shop where you got it.
May 17, 2009 | LG Prada KE850 Cellular Phone
No , i cnanot switch the phone in my pocket pc
WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?WTF?
SPEAK ENGLISH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 01, 2009 | i-mate JAQ3 Smartphone
xheli Double Horse 9074 3 CH RC Metal Helicopter w Gyro  Flashing LED Balance Logo
384 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
