Question about Maytag Neptune MAH9700 Front Load Washer
I need instructions on how to replace front boot seal on my neptune front load washer
  • 1 more comment
  • timn596 Jan 04, 2011
    The solution offered is not for my model of the Maytag Neptune I have. My complete model number is MAH 7500 AWQ. It is the model that has all it's operating buttons on a raised back panel. These buttons are "touch" buttons, not traditional push in ones.
    The solution offered to me looks to be of an older model with front panel operating controls etc.
    thank you, tim
  • timn596 Jan 06, 2011
    The model number you sent me instruction for is incorrect. My Maytag NEPTUNE is a MAH 9500 AWQ. This makes the 4th time I have sent this information in, and still have not received the correct response. Time is money, and mine is way over due.
    Please help, tim
  • timn596 Jan 08, 2011
    i HAVE COMMUNICATED NOW FOR THE 5TH TIME with "FIXYA" THAT YOU SENT ME THE IMPROPER MODEL NUMBER [9700] INSTRUCTIONS, AND THAT MY MODEL IS MAH 7500 AWQ.
    I need the right instructions for my model replacement of the "boot seal"
    President:
  • 1,554 Answers
Disconnect power supply to unit then remove 2 10mm screws from washer back.
Slide the top cover towards the rear to clear the screw head from flange on the bottom side of the top cover.
Pull the dispenser drawer out completely then remove five screws attaching console as shown. Roll the console down and lift it I need instructions on how - jahn27_68.jpgher.
Open the door then expand the boot clamp spring located at the 6 o'clockI need instructions on how - jahn27_69.jpg remove the boot retaining clamp.
Pull the boot from the lip formedI need instructions on how - jahn27_71.jpgnt opening then remove the four screws attaching the top oI need instructions on how - jahn27_72.jpganel to the cabinet.
Lean the front panel forward then disconnect the wire harness to the door lock and switch asI need instructions on how - jahn27_74.jpgjahn27_73.jpg
Lift the front panel off the bottom brackets anI need instructions on how - jahn27_76.jpg of the way.
Loosen the boot clamp at the 12 o'clock positI need instructions on how - jahn27_77.jpgve the **** and the boot.
Install the new boot aligning the index tabs on it with the screws on either side of the fill tube.
Secure the boot with the clamp then reconnect the door lock and switch assembly harness and reinstall the front panel. Put the boot over the outer lip of the door opening then secure it with the boot retaining spring. Reinstall the console and the top cover in reverse order of the removal steps.
Please make sure to accept the solution should you find it helpful. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 03, 2011
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is a link that will help you thru the process.
Posted on Jan 04, 2011
  • Gregory Prince Sep 08, 2013
    This was exactly what I needed. Very easy replacement process. Most of the work was cleaning up years of spilled detergent and some corrosion due to water and liquid soap spills.
2 Suggested Answers
  • 530 Answers
SOURCE: I need to replace the molding door boot seal on my
you need to first unplug the unit. next you need to remove 4 screws that hold the dispenser lid on. next open the door remove 4 screws. remove the door and the out side panel. next located to the top left and right you will see a bracket with a 5/16 bolt remove them and take the bracket off. next lift the lid. you will have access to the door seal. you will see a spring at the top that is the band that holds the seal to the tub. the front of the seal just peels off. when putting the band and spring back on may be a little tricky. get one side up to the top gett a piece of duct tape and secure it. so that you can properly get the rest of the band on without fighting with it. get some vise grips and pull the spring over and attach to the part that is tapped. let me know if this helps or if you need more instructions.
Posted on Jun 21, 2009
When the washer is spinning it is very loud.
you need to replance the drum bearings and water lip-seal behind the inner drum,it requires you to completely dis-assemble the machinesfront cover,then remove pulley from drum in rear,drum boot seal,then knockout bearings and seal and replace these then re-assemble the machine in reverse order
Jul 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
We are having a leak on the bottom of the front loader door on the wash cycle
Check the door seal. There is a boot drain on the seal that may be clogged. This drain allows the water to drain out of the seal when water gets in there. You may need to replace the seal. HEre is a link to the part you will need.
Happy Holidays The FixYa Team
Dec 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I need to replace the molding door boot seal on my Maytag Neptune front load washer, where can I get instructions?
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH9700 Front Load Washer Logo
308 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
