Question about Boating
Just bought a second hand 40hp tohatsu took it out bu water was not continuly coming out when motor is running have stripped down and parks all look ok in shaft. Also what gasket sealer should i use when putting back together. thanks Mark
    Champion:
  • 202 Answers
You have a thermostate water will come out real slow till it warms up should get full stream when full open if not change water pump and thermostate
Posted on Mar 16, 2011
To extend leg 6 inches on a tohatsu 90 hp m90a boat motor do i replace the drive sharft or put an exta ension n
fit a longer leg section to the power head
talk with a tohatsu service agent for the longer leg
Dec 28, 2017 | HP Boating
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 | Boating
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
Frigidaire dishwasher motor sqeels when it comes on, lower blade wont spin. nothing clogged, took apart everything down to the impellar. impellar doesnt spin to send water to blade but the back fly wheel...
Sounds like an impeller and seal kit you will need I think you impeller jammed up and the shaft stripped out the impeller or your motor shaft snapped
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Nov 19, 2017 | Frigidaire 24 in. FDB435RFR Built-in...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
Engine cuts out while running
Sounds like a coil pack getting hot and breaking down
Aug 07, 2009 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
2003 Ford Taurus SEL Rear Window Wont come down
if window wont work with either switch the 1 on the drivers main switch or the one on rear door it may just be stuck on weather stripping and may need help down with door open have someone press switch and w/ door open put hand on inside and out of glass pushing down if it starts working agian spray weather strip with silicone spray if it does not work need to test motor to see if its getting batt voltage if not its switch if it is u need new motor
Mar 28, 2009 | 2003 Ford Taurus
Boating Logo
190 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
