The tv keeps clicking and making the start up noise but will not cut all the way on. what could it be? and any idea on where to find the replacement part(s)?
    Problem Solver:
  • 12 Answers
I had this problem on my Samsung. Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
My saw makes a loud noice while I'm cutting
I'm wondering what the noise is like. Is the noise only while you are cutting / under load? Is the blade smoking? What type of wood are you cutting?
Jun 21, 2014 | Dewalt 12" Beveling Sliding Compound Miter...
My TV keeps switching its self off, it makes a clicking noise as if its trying to switch on. Then cuts out.
Do to the clicking noise your tv makes is a very common idicator that your power supply in the tv is failing. Its an easy fix lots of DIY videos on youtube but may cost you a arm.
Apr 29, 2013 | Philips 28PW6506 28" TV
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
Samsung TXS3082WHX/XAA
The relay cuts inside the TV after swich on. Should be some short circuited component/board inside it. Check and replace it. The click sound you hear is of the clicking of the relay. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 29, 2012 | Samsung Televison & Video
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
Jul 04, 2012 | Suzuki Motorcycles
1996 dodge wont start keeps draing batteries
sounds like an alternater problem. the batt is not charging and is only running off the batt untill it runs out. check the wires ect on the alt and if that doesnt work, get a salvaged alt.
Aug 18, 2009 | 1996 Dodge Neon
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
2 tv's when I try to cut them on they make a clicking noise
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 15, 2009 | Toshiba 27A62 27" TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
