Question about Honeywell Heating & Cooling
We just installed a honeywell thermostat, our furnace is an old furnace and now it won't shut off. it is a hot air oil furnace. any suggestions
  • 784 Answers
For a quick test -- remove the wires from the thermostat and see if the heater shuts off then,,, if it does shut off then the problem is the type ( model ) of the thermostat and it may not be compatible with that heater or there is something wrong with the way that the thermostat is wired. ( make sure that the thermostat is reading the correct temperature and is in fact in the off position ). also double check the wire color code at the heater and make sure that the right wires are connected proper.
what model is the thermostat ?
c...
Posted on Jan 03, 2011
Can I install this thermostat to a Geo Thermo Premier 2 Water Furnace with the following wires connected as follows from old Honeywell thermostat TA511M1010? Old connection; R, C, Y1, W, Y2, L, O, G
Yep, you should be able to run your water furnace with the thermostat. Just wire it up same letter to same letter on both devices. If your thermostat worked before, it should work again. I couldn't find the honeywell part you listed, but the terminal designations tell enough on their own. Don't forget to shut off all power sources before doing any wiring, and to configure the control board on the water furnace before switching the thermostat to any active mode.
In case you don't have it, here's the install guide3 for the water furnace.
http://www.waterfurnace.com/literature/premier/IM1555.PDF
Please mark me helpful and feel free to ask more questions in this same thread if you need to.
Jan 03, 2015 | Honeywell Heating & Cooling
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
Honeywell thermostat RTH6580WF heat is ok but a/c doesnt cool
Same problem here. Gas, hot air furnace with A/C. Fan works with heat, but not A/C. Furnace is old, and I had to move the G wire to C at the furnace, plus install a jumper from Y to G.
Apr 10, 2013 | Honeywell Programmable Thermostat Heater
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Hi my oil furnace keeps comming on every 10min the system is 1 year old and i just installed a new homeywell thermostat and set the gauge at 50 and the temp. is 80 that is way to hot in here.
Cut the unit off it sounds like it is tripping on high limit this could be dangerous.
Take the wires off of your primary control and see if this stops the furnace. the wires should be marked t and t Post me back with details
Nov 28, 2008 | Honeywell Heating & Cooling
I've replaced my very old (mercury) Honeywell thermostat with a new one (round, Model: YCT87K1011), but I can't get it to control the temperature. If I connect the two wires one way, the furnace comes on...
Hey John, man that ole T87 has been around for a hundred years and I have installed many of them, but I cant remember the letters on the wiring. Seems to me that it is R-W-Y, any way you will use the R and W. I have a t87 at home still in the box and I could wait till I got home to help you but Im sure its the R and W terminal. Dont forget to set the heat anticipator. Set it the same as the current value of your gas or oil valve.
Nov 06, 2008 | Honeywell Heating & Cooling
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
105 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
