Question about Zanussi FJS1225W Front Load Washer
Zanussi jet system 1000
Code e90 displays and beeping sound is heard when washer turned on.
  • mccalmont4 Jul 14, 2008
    had probs with washer leaking ,cleaned filter and pump ,now only slight leak but error e90 keeps coming on but that code not in my book its a zanusi jet systemturbo dry 1600 help please
    Problem Solver:
  • 10 Answers
A E90 fault code means the main pcb board is faulty and i'm afraid to say, they are a expensive item and not always easy to replace, some come pre programmed and just swap across and others have to be programmed using the code on the white sticker on the board housing. either way it normally better to get a engineer to replace it because you don't get the programming instructions with the new pcb. I hope this helps
Posted on Jul 18, 2008
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Zanussi jetsystem 1400- error e90
    e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    Continuous beeping with only the on/off button lighting up
    this sounds like a configuration of the electronic problem. error e90 there are at least 9 beeps . can be badly connected wires particularily between main board ond front display board but usually ends up with a new main electronic (£120) also configuration is a complicated operation.
    Jun 12, 2010 | Zanussi FLE1416W Front Load Washer
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    E 20 ERROR ZANUSSI JET SYSTEM
    E20 is a general error code to get to the real problem try this..
    Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
    Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
    My zanussi will not turn on at all.
    If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
    Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
    E90 code on a zanusi jet syatem turbo dry 1600
    Jul 14, 2008 | Zanussi FJS1225W Front Load Washer
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    ZANUSSI ZWD1471S
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    303 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
