Question about GE Refrigerators
Can part PS288339 be easily replaced or does it require a technician?
2 Suggested Answers
  • 6771 Answers
SOURCE: stirrer motor
I would recommend a technician for the job. It can be a tricky repair.
Posted on Apr 08, 2012
How can I replace the lamp in an unidentified sewing machine?
The Owner's Manual would be most useful for this information. If you don't have one, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Some sewing machine bulbs can be replaced easily but more and more new machines require that a technician replace them.
Mar 22, 2016 | Sewing Machines
How to recover deleted messages
In this article, you will meet a very good recovery program that will handle all the stress for you. It won't require a technician after all. You can do the job easily and faster.easily and faster.
For better step by step procedures follow these guides:
Step1. Download FoneDog - Android Data Recovery, Install and Launch
Step2. Connect Samsung Galaxy S Note to the computer
Step3. Select Files for Data Extraction
Step4. Select Device Fault Type
Step5. Download Mode
Step6. Retrieve deleted messagesby preview and selection
You can learn more from the articles below:
Feb 26, 2013 | chatango.com
Camshaft bearings replacement
Which engine? Do you have the special tools required for the job? Installing cam bearings is difficult and in my experience best left to a machine shop to do or a very skilled technician. You can ruin a new set of bearings very easily.
Jul 24, 2012 | 2000 Dodge Dakota Quad Cab
Stirrer motor
Apr 07, 2012 | Whirlpool MH7130XE Microwave Oven
My epson stylus photo TX710W printer is saying that the ink pads ar at the end of their service life and now doesn't print. Is there any way to reset the ink pad counter?
Take the printer to a qualified technician, who can "service" the ink-pads (by replacing them) and by resetting the printer to indicate that "new" ink-pads have been installed.
Jul 16, 2011 | Epson Office Equipment & Supplies
Haier RTC1700ss digital display doesn't work. Beeps when plugging in but no functions
Hello
Here are a few things you shoul look at and try to correct to make your oven work properly
Make sure the electric oven is plugged in properly.
Check that door closes completely and its latch is aligned.
Check that interlock switch in door works properly (required for activating oven).
There might be a blown fuse,replace blown fuse if it's accessible, or contact a service technician.
Inspect plastic coupling beneath tray.
Check ring and roller assembly for misalignment or debris.
Make sure that tray is sitting properly on turning mechanism.
If carousel motor is broken, contact a service technician
Make sure there's no aluminum foil or metal trim on dishware.
Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
Sand away burn spots, and smooth rough metal edges.
Touch up spots with microwave interior paint if necessary.
If chamber has burn holes, contact a service technician.
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Jun 20, 2011 | Haier RTC1700SS Electric Single Oven
3 lights flash and TV will not turn on
Since your TV is a DLP, it could be the lamp or the color wheel. The flashing lights are a service code. Some TV manuals will describe the code and others require a service manual for the codes. Either manuals can be found online at a reasonable price. Here is a site I use.
http://www.servicemanuals.net/service.aspx?gclid=CPiusPKC0aYCFUVqKgodNzTUHA
My sharp DLP allows for the user to replace the lamp pretty easily so there is a chance you could be able to replace yours if that is the problem. The color wheel is a different story. That will probably require a service technician.
Good Luck
Jan 23, 2011 | Samsung HL72A650 Television
Need a door seal replacement. Does it require a
Really need a model number to answer for sure.
Most of them go on easily. You can do it.
Sep 08, 2009 | Maytag Dishwashers
Have a Canon Power Shot SX100 IS...Lens error, restart camera... I have changed the batteries, etc., however, the lens will not "colaspe"... PLEASE HELP!!! Thank you...
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jun 27, 2009 | Canon IXUS V2 Digital Camera
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
