I have a Samsung HLN507wx/xaa. I just replaced the colorwheel and the lamp. The set will turn on but no picture. The lamp will not turn on at all. If I take out the lamp and look the colorwheel is not turning. The set has a blinking green light and turns itself on and off every 15 or so seconds.
    Problem Solver:
  • 12 Answers
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
COLOR WHEEL
try to see the settings from your remote control or see the manual for more information.
CHARCOIS
Sep 07, 2008 | Samsung HLN567W 56" Rear Projection HDTV
MY SAMSUNG HLN 507 WX/XAA T.V. IS MAKING A WHINING SOUND WHEN I TURN IT ON
Your color wheel is going bad, when it fails the TV colors will be way off and it will shut down. They range from $50 -$125 . Here is one for $98 for your tv. http://www.amazon.com/Projector-Replacement-Samsung-HLN507WX-HLN567/dp/B00HJOLQ7G
Jan 09, 2015 | Samsung Televison & Video
I have a HLP5063wx/xaa and when I turn if off I hear something like a fan winding down. Also every once in awhile when I turn it on the people are red but i turn it off and back on and everything is
Yes the fan can be replaced but I believe your issue is actually the colorwheel which is going bad which can lead to color issues eventually the set will refuse to power up if the bearings fail completely inside the colorwheel
Jun 15, 2012 | Samsung Televison & Video
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
My 56" samsung hlr5667wx xaa the picture turned purple, then no picture and loud buzzing. the TV would not turn off had to unplug to stop the buzzing. What should I do?
Its your colorwheel,don't get one from a guy on Ebay for $118.00 his are defected ,try partstore.com.
PS(Please rate my service ,Thanx!)
May 24, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Picture is black and white and fleckers. changed
In most cases this is due to the fact that the color wheel has shattered into pieces and will need to be replaced. Replacing the color wheel is not too easy, but if you are technically handy it isn't that tough to replace either. The part number for the color wheel is BP96-00250A and will run between 80-130 dollars for the part.
Nov 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN507WX/XAA - Bad Picture
its sounds more like the digital board that needs to be replaced
May 04, 2009 | Samsung HLN507 50" Rear Projection...
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Electro Med Services...
