Hi, I have a WARMAIRE wood burner and i am looking for a manual that shows how it is assembled and installed. I need to to remove it to repair it. Are you able to please assist. Its an older unit and i would gues its at least 10 to 15 years old. regards, Louie
4 Suggested Answers
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
  • 11800 Answers
SOURCE: Dear Sir/Madam, I got a Daikin
The only online manual i could find - for a model similar to yours
http://www.klondaik.com.ua/data/image/download/05_30_08_17_08_23.pdf
Posted on May 27, 2011
rockmeister
  • 2047 Answers
SOURCE: Hi I have an Arrow Wood
hello peter, 18 years is quite a long time to use a heater. These units are repairable although as you said the 18 years of use has ensured that no information about this unit is readily available as it has been discontinued and replaced for well over a decade. usually any HVAC tech should be able to get replacement fans or motor for the unit. Although i doubt if the fan or motor is bad the noise might just be due to some interference in the unit.
Although i would also advice that if you can afford it just get a replacement unit as the unit is already considerably old and is prone to failure in the near future.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Jul 15, 2011
Baffle plate for Henden wood burner
hi alistair.
not sure if this is what you are after,but go to this link and see if its what you are looking for.
Baffle plate for Henden wood burner Google Search
Nov 03, 2017 | Cars & Trucks
Is there an online video or written instructions about how to replace a burner on a Broilmaster D4 grill
Unfortunately, the D4 series grill hasn't been around since Martin Industries went bankrupt 8 years ago and Empire Comfort Systems to over Broilmaster. However, today's 'P' or Premium Series is the closest to the old D4 series, as far as burners and burner installation and removal is concerned.
I have included a link to the Owners Manual, which shows how to assemble the grill and install the burner(s). Just do the burner installation in reverse. You can download and print the manual for future reference.
http://www.broilmaster.com/BROILMASTER/pdf/2010/B101362-2-0610-P3-2-P4-1.pdf
Hope this helped you. Please let me know. Happy Grilling!!
May 13, 2011 | Broilmaster Deluxe D4 Grill
C2 11 error code im a master plumber and put this in my own home , and also have owned my own business for 15yrs and im getting this code. i no this unit is installed correctly for a fact what the heck is...
As a professional plumber, you know all costs are energy, which is why you recommend replacement rather than repairs that need repaired over and again.
http://waterheatertimer.org/Hidden-cost-of-tankless-water-heater.html
I certainly believe tankless are a waste of energy.
Open following link to see list of UN-answered fixya questions about 1 model Rheem tankless:
http://www.fixya.com/tags/rtg_74pvn
That being said, C2 11 code has to do with gas supply, venting, which could be external cause or internal part failure, or combination.
Typical manual shows error C2 11 on page 33:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Typical manual also shows regular maintenance on page 29.
The word maintenance is used throughout manual.
Tankless are prone to lime build-up and should be de-limed each year, and cannot be exposed to more than 11 grains of hardness in the water.
Research shows that regular de-liming will not restore full efficiency to tankless water heaters:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 15, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
There was no users manual with the smoker. do i use charcoal or lava rocks and where do i put them
I have used a number of propane smokers and your propane burner will be located at the bottom of the smoker cabinet and you should have a wood / charcoal box above that in which you can place your charcoal or wood.
I have attached a picture that shows the wood / charcoal box. It's not the same smoker but it will give you an idea.
Hope this helps.
Cheers,
Nov 25, 2010 | Masterbuilt 20050106 Propane Smoker
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
Water heater burner assembly.
If you check with manufacturer, you may find out that changing the orifice in the gas valve, is all that is necessary. If you can't get information, get back to me with make, model and serial number off the heater and we'll see what we can find out for you. You might find that a local gas appliance dealer, or technician can do that for you at a reasonable price.
May 01, 2010 | Reliance & 30 Gal Mobile Home Water Heater...
Mystery Part - Cover for Wood Chip Burner?
Although not shown in the Owner's or Installation Manual, I finally found a parts list and accompanying parts diagram it is shown there... it is a "top heat shield" and seems to go over the "smoker burner," just resting on top of the brackets around the burner, hole toward the back. Poorly designed installation plan and unbelievable that it is not mentioned or shown in any manual.
Jan 18, 2010 | GE Monogram ZGG27N21CSS Grill
Water heater not working. shows c2 than 11. any suggestion?
First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board . You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. All that you need is a long phillips screw drive and a drill because its about 25 screws the burner assembly has 2 screws all in the back, underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Good Luck
Nov 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Heating & Cooling Logo
560 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
