Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
WON'T STAY LITE CODE C211 - Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
  • Barrett Palumbo
    Barrett Palumbo Jan 03, 2011
    two many digits is it C 21
  • haee_gordon Jan 03, 2011
    WORKS SOME TIMES BUT NOT MOSTLY CODE C211
    New Friend:
    Problem Solver:
  • 7 Answers
Ain't necessarily so. I just went through this. The unit worked flawlessly for six years then crapped out with a code 12. Using the engineering manual available from the Paloma site, I removed the complete burner assembly and sanded each flame rod and igniter. I brushed the burner assembly with a stiff paintbrush and reinstalled. Worked better than it has in a long time. The flame rods and igniters get a crud build up that needs to be cleaned off. It is a major disassembly including removal of the PC board - but the connectors will only go on to a particular spot.
Posted on Apr 12, 2013
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your error code, is you have clogged burners, and they will have to be cleaned,
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Posted on Jan 03, 2011
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
MODEL NO. RTGL 74XN\r\nNOT WORKING SAYING CODE [C211]
Before calling service technician, open following links for Rheem troubleshooting resources:
C2 11 is no ignition:
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater should have yearly maintenance that includes cleaning burner parts, with check of ignition parts, wiring, ignition sequence, gas supply, and bleed gas line if needed.
Chances are that your unit needs to catch up on maintenance.
Maintenance can also catch any condensation problems and make venting adjustments so parts are not degraded due to vent issues.
Tankless should also be delimed each year to preserve efficiency of heat exchanger.
Jun 29, 2011 | Rheem Tankless Water Heater RTG-74XN-1,...
We have no hot water and error code c211
call here for your answer
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Piolet lite will not stay lite. Takes awhile to lite after it dose lite it kicks off again
Sounds like a bat thermocouple to me. Replace it they are not very expensive.
Good Luck,
Gil
Mar 01, 2010 | Reliance & 30 Gal LP Gas Water Heater
Wont stay lite
I recommend contacting the company and asking them to send you a new thermocouple. This is easy to change and will most likely solve your problem. When you contact them have all of the information ready such as model #, serial #, date of purcahse etc., whatever you have. good luck
Jan 21, 2009 | Water Heaters
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
299 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
