Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
How can i get the stand off of the tv to hang on the wall?
  • Sharp Master
  • 736 Answers
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Posted on Jan 03, 2011
I have a 50 inch sceptre x505bvf i need the screws for the back to hand tv on tv stand
When you purchase your stand or hang on wall, they come with universal screws to hang untit.
If not go to sceptre.com and request or purchase missing screws.
May 29, 2016 | Sceptre Televison & Video
How do i remove the tv stand from a 42 inch flat sreen so i can hang it on the wall
With the tool you will be using to remove the stand remove the screws from the bottom back of the television and remove the stand.
Jan 08, 2011 | Televison & Video
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Took 6 screws out of back of stand on my Olevia TV, but still can't remove stand so I can hang TV on wall
I just wrestled with this problem. The screws were backed all the way out but I could not remove the stand. I had to remove the screws completely from the holes, then the stand can be pulled down then off.
Oct 19, 2010 | Olevia LT32HVM 32 in. LCD Television
How do I take off the stand? I just hung the TV.
Take the TV down. there are 4 Phillips head screws one the back bottom that hold the stand on. take them out and lift the TV off the stand and hang it back on the wall. be sure to remove the stand screws and not the screws that hold the TV together.
Jan 11, 2010 | Akai LCT42Z6TA 42 in. LCD Television
How do you hang on the wall- i cant release the stand - help
If this TV have 4 fixing holes on the back (should be 100x100mm - VESA standard 100) then it is wall mountable and the stand should release - its normal to have a clip system or bolts holding the stand into place.
See this guide for more advice:
http://www.mountright.com/articles/?s=mount
Sep 14, 2009 | Astar LTV-19BG TV
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Can't stand my tv straight up.
easy, order a new Base for the television, or get a stand that has back mounts, they cost about 200-400 bucks. goto costco and you may find a cheaper one.
Trust me i am the flat pannel guru.
May 02, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Removing the stand
Check to see if you got all the screws, usually there are 4-6 screws holding the stand in the TV. The are usually all on the center bottom on the back. When the TV is on the floor, try lifting with two people, one on each side directly up evenly. The stand should stay on the floor as the TV is removed.
Apr 02, 2009 | Sony KDL-52XBR5 52 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
746 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
