Question about Mustek MP72 Portable DVD Player
Lense not reading properly
The move is getting stopped while playing. The lense is not working properly. What is the lense number for MP72 player so that I can replace the lense.
Check to see if it is not the lens, but rather the fact that the little tab on the lid that closes the disc compartment is not making firm contact with the mechanism that tells the disc to play. I had the same problem (player would play for a couple of minutes, then it's stop and I'd get an "Open" message. I called Mustek and they unhelpfully suggested various tricks to do with the lens carriage, none of which worked. On my own a carved a matchstick to the shape of the tab on the lid, and stuck it in there. That worked! Eventually (since you can't watch it with the lid up), I just put some duct tape (a little pice) around the tab, and that has worked like a charm. Makes it hard to open the lid again (I use a knife to pry it up), but hey--the player works now!
Posted on Sep 26, 2008
Getting message - "can't read" & "no disk"
sounds like the laser is out of synk with the encoders inside the player, to fis this you will need to disconnect everything from it, unscrew it and carefully move the lase all the way to the outside of its track, BE CAREFUL NOT TO TOUCH THE LENSE WITH YOUR FINGER, you may also wish to clean the lense while you are in there anyway. To do this dip a cotton swab in Isopropyl alcohol (the kind you use for cuts and scrapes), and roll the tip accross the lense of the laser, just let it air dry. Reassemble the player and it sould be good to go.
Jun 30, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My DVD player is becoming very selective about the DVD's it will play, and the ones that it rejects as the wrong "format". It seems to be getting more selective by the day, and prefers newer...
Ya, it does sound like the lense is dirty. To clean it you can pick up a cleaning CD or DVD. It basically will clean your lense while it plays. You can find them at bestbuy or circuit city. The CD actually has a brush on it and will wipe the dust from the lense while the disk plays. Keep me posted. If you thought this solution was helpful please rate it when you get a chance. Thanks - Tech101
Jun 25, 2008 | Televison & Video
Was working fine then all of a sudden, when I put in a disc to play the display says "no disc"? Then it won't do anything at all.
You lense has stopped detecting u need to chande lense or open and clean the lense
Dont forget to rate
Sep 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
JVC home theatre system DVD/CD player has stopped working.
Please check the dvd layer lense. When there is lense problem this issue will occur.
Apr 03, 2009 | Audio Players & Recorders
DVD wont read
This is because of the lense problem, and there is a alignment problem, i mean to say that the lense tuning is almost gone......!!!!
if you want to resolve your issue, better you change the entire lense set to work properly.
Mar 21, 2009 | Audio Players & Recorders
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Pioneer PD 8700
I think you are right and glue has got on the lens blocking the reading of the disc. If you can remove the glue without scratching the lens, it should cure it. Otherwise you need a new lens.
May 17, 2017 | Pioneer Audio Players & Recorders
Loading stopping
if it is not playing dvd the lense may not be able to read the dvd's you can play the dvd's by changing the lense it will be ok
Jun 13, 2007 | Durabrand DUR-1700 Portable DVD Player
Mustek MP72 Portable DVD Player Logo
147 people viewed this question
Top Mustek Televison & Video Experts
richie46
JonSnell Electronic
JonSnell Electronic
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
