Question about ATSI Holdings Axiohm A795 Thermal Printer
Need a set up manual for Axiohm A795 Thermal printer.
    Genius:
  • 1,739 Answers
You should be able to find everything you need including a manual here:
http://www.tpgprinters.com/downloads_8.aspx
A tough search! Trust this is helpful. Please vote.
Posted on Jan 03, 2011
Warning ribbon in
the ribbon sensor it activated, change settings from lcd panel to Direct thernal, and check if settings from driver are correct, Thermal Transfere if using ribbon, Direct thermal if doesn't use ribbon, ru calibration if needed, or if doesnt work, you can do the manual calibration and/or reser to factory default. Hope it helps. Paulo.
May 16, 2014 | Zebra S4M Thermal Label Printer
Ribbon error on B-EX4T1 with direct thermal labels
First of all, With any Toshiba label printer, after a parameter reset, you must send a label before doing a feed. Otherwise the printer will try to feed the ribbon.
You can use the setting tool to tell set the printer to direct thermal also.
Easiest way is to use the windows driver , add a label format coresponding to the one you are using, verify in the support tab that you are in direct thermal, do a test test print from the driver and you'll solve your problem
Apr 17, 2014 | Toshiba TEC Office Equipment & Supplies
Samsung SCH-A795 Cellular Phone Unlock code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 Default 6 Digit Security code: 000999 or 1122 Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved OR: If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Oct 04, 2011 | Samsung SCH-A795 Cellular Phone
Ribbon feeds out with label on the intermec easycoder PM4i
check setings Printer or Driver
(Direct -Thermal - labels without ribbon or Thermal transfer if use ribbon).
2nd solution install segull drivers (www.seagullscientific.com) and you can reset to factory defult if you need.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
RIBBON IN
The RIBBON IN message means that the printer is set for Direct Thermal printing. Check your printer driver - Each driver is a little different but there should be a setting for choosing between Thermal Transfer and Direct Thermal printing.
Once set to Thermal Transfer, the error will go away.
Hope that helps !
Apr 29, 2010 | Zebra S4M Thermal Label Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
Can't get info
If i am not mistaken this is a USB 2.0 hub.You can always put in on a vista machine with usb 2.0 nd if it is not USB 2.0 it will notify you.
May 05, 2009 | ATSI Holdings Axiohm (Now Pertech) A716...
Thermal printer settings
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please reference the user’s manual on page 11 and 12 for dip switch settings.
Jun 03, 2008 | Samsung SRP 350 Thermal Printer
ATSI Holdings Axiohm A795 Thermal Printer Logo
193 people viewed this question
Top ATSI Holdings Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an ATSI Holdings Office Equipment and Supply Expert? Answer questions, earn points and help others
