Question about Kodak EasyShare C613 Digital Camera
Batteries dry so quick - Kodak EasyShare C613 Digital Camera
  • 133 Answers
How long have you used the camera?
normally, the battery life will lasts for one year
Posted on Jan 03, 2011
How to Save my Laptop from Dying Because of a Liquid?
John Roush...
Quickly
Shut off all power...
remove all batteries.. dry, vacuum or blow dry the offending liquids from the unit.
Time is of the essence.
Consider calling a "service" that uses dessicants to dry electronics... I'm thinking Serv-pro would be a good starting place.
Mine was a cup of coffee... so I followed the coffee ream & sugar with clean water ... towel dried ...splashed with alcohol... and used dusting cans to dry everything
(but I know how to completely burst old DELL C640 &D800s completely apart.
Electrolysis/corrosion is the enemy you must beat...
Time is of the essence... remove ALL POWER...!!!
Oct 18, 2016 | Computers & Internet
WHY ARE THE BATTERIES IN MY PANASONIC LUMIX DMC LS80 DYING QUICKLY?
Always be sure the batteries are charged and suited for your device.
Check contacts of the batteries and in the battery compartment of your device. Dirty or oxidised contacts can be cleaned with a dry cloth, or a cotton swap. Never use sharp tools to clean contacts or anything sharp in or on electronic equipment.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
NEVER use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Feb 24, 2015 | Panasonic Cameras
WHAT IT MEANS BY NO POWER REMAINS BY LX5
I can't find this message in the manual. Power failures are the most common errors with portable gear. You have to rely on the quality of the batteries. Each and every battery can become faulty, with no obvious reason you can think off. Using lots of rechargeable batteries myself, I think I know where I'm talking off.Please to be sure, take another set of batteries, charge them and put them in the camera. Try to avoid alkaline batteries, because they only are capable of doing half the job of an rechargeable NiMH, pro charge. Also never use NiCD rechargeable batteries, because they won't have the correct voltage. (perhaps one or two shots, but the voltage drops very quick to 1,2 volt, its working voltage).
You also can check the camera and the batteries, if they don't have dirty or oxidised contacts. Only clean contacts with a dry cloth. Or when really dirty, with just a little contact oil on a cloth to wipe the contacts. Be sure you dry the contacts after the cleaning. Never use sharp tools to clean electronic contacts.
Nov 25, 2013 | Panasonic Lumix DMC-ZS3 Digital Camera
The camera ran out of battery and I put in 4 new alkaline batteries. Now the camera won't turn on at all.
Unless the batteries are in wrong they must be dead. try to use new ones and check for the instalation some of these cameras use wierd configurations on which is positive and what is negative.
May 25, 2011 | Nikon Coolpix L110 Digital Camera
My samsung L730 digital camera will not turn on, i have charged it overnight and am using a lithium ion rechargablt battery that came with the camera
Some lithium-ion really loose their life easily and sometimes quickly.They are affected by temperatures too.I noticed that when I am charging the batteries tend to heat up and I found out they loose their power quickly when you let them charge and leave them warm.Secret to of prolonging their life is after a full charge zip lock it and freeze them.Of course dry them upon use.Do try a new set of batteries it will resurrect your camera back to life.
Nov 25, 2010 | Samsung L73 Digital Camera
We just replaced our Scrubbing bubbles automatic shower cleaner. We put brand new batteries in the unit. Compartment is dry. When we push the start button, it beeps at us and starts to spay for not ...
I've found that the batteries lose contact after w while, so here is what I do:
1) take a pencil eraser and rub each of the contacts with it.
2) lightly apply some petroleum jelly to each end of the battery.
3) make sure the compartment is completely dry. Take a small piece of paper towel, roll it up, and, with the pencil, rub the inside of each of the battery compartments.
4) re-insert batteries and try again. It should work!
Sep 05, 2010 | S. C. Johnson & Son Scrubbing Bubbles...
My chair is not charging. We are getting 34 volts
Hi. A voltage of 34 volts is way to high. Most chargers are limited to about 28.5 volts. You will quickly dry out your batteries at 34 volts. I would say your charger is very faulty.
You have probably already destroyed your batteries at that charge rate.
Are the batteries new or a couple of years old.
I serviced a machine last year, that, according to the owner, had been through 6 sets of batteries in 4 years. His charger had the same problem as yours.
Good luck. Neil.
Jun 20, 2010 | Jet 3 Ultra Power Chair
What battery would you suggest for my 1996 Maxima. I live in northern Mass.
The best batteries I've had (and the only ones I buy) are Optima deep-cycle (dry cell) batteries. The red-top battery is great for us who live in the northeast, with the cold of winter. They have 900 crank amps, recover very quickly from a discharge, and last a long time.
Dec 10, 2009 | 1996 Nissan Maxima
Canon camera sx10 IS battery dries out quickly
please use the batteries of the same spec. IE - 4 two 3000mA. please read the instructions carefully - they do mention that you have to use battiers of the same power rating.
Aug 08, 2009 | Canon PowerShot SX10 IS Digital Camera
Dropped my e550 in the river
I'm afraid so. The insides of these types of cameras are very compact, with layers of circuitry and connections. You might have been able to save it (a slim chance at best ) if you had gotten it to a repair shop or removed the covers and dried it quickly.
I have rescued cel phones (my own), film SLR camera and lens from water damage, but they were still wet when I started. Your Fuji would be a pain to take apart since they used the tri-head screws on that model
Jul 24, 2008 | Fuji FinePix E550 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
15 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
