Question about Fujitsu FPCKB41A1P Keyboard
I typed j,k,l and number 1,2,3 came out? - Fujitsu FPCKB41A1P Keyboard
  • 2,418 Answers
On the key board is a [fn] key press this key and then a number key to get numbers, press it again and then a number key to the letters back.
Posted on Jan 03, 2011
Where is serial number
Usually serial number you can find written in sticker back of your laptop. If not
1. Go to command prompt
OR
1. Press and hold window key and press key "R"
2. Type:- cmd and Enter
3. Type:- wmic bios get serialnumber and Enter
May 11, 2013 | Computers & Internet
Where do I find a parts list or be able to get parts for porter cable 6" boss circular saw
Go to http://servicenet.deltaportercable.com/
On the left hand side, you'll see a search box where you can enter your model number.
On Delta ' Porter-Cable tools, the model number and type number are usually on the warning label or name plate.
  • These labels are typically found on the bottom or side of the tool.
  • For larger equipment, the label can be found on the top of the equipment.
  • Sometimes the type number is reflected at the end of the model number. The type number can be followed by a " - " or a "T" at the end of the model number. For example: "HFAC3030-1", is a Type 1. "36-450 T2", is a Type 2
Dec 29, 2010 | Porter Cable 345 6" Circular Saw Saw Boss
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
How do i type roman numbers on a computer?
I think you are talking about bullet points, right? You have to start a list and right click on the number. Then go to Bullets and Numbering and select the type of Roman numerals you like (lower or upper case).
Nov 03, 2010 | Computers & Internet
How do I enter numbers/use the speed dial? Any Manuals available?
when you want to enter a number on a speed dial you first want to go on the page with your contacts (where its has all the options : groups, contacts, new contact, etc...) look down the list and you will find "SPEED DIALS" click on that then numbers will apear 1-*lets say* 999 click on the first empty one and it will let you add a number or contact that you type in or choose. Then when you want to use the speed dial to call lets say "George" and he is your speed dial 1 just type in the number 1 as if you were typing in a phone number and his name will come up on the top of the screen or such and you just have to press call, or you can hold the one down and it will imidietly call "George"
Apr 27, 2010 | Lands Phones
How are the cylinders numbered on a 2001 S 4.0?
For the 2001 Jaguar S-Type 4.0L:
Cylinders:
B .....(back)......B
A 4...............4 A
N 3...............3 N
K 2...............2 K
# 1...............1 #
1 .....(front).......2
(BANK #) - CYLINDER #
(1) - 1... (2) - 1... (1) - 4... (1) - 2
(2) - 2... (1) - 3... (2) - 3... (2) - 4
Mar 09, 2010 | 2001 Jaguar S-Type
What is the difference between Porter-Cable air compressor models that have a type 1 or type 2 behind the model#?
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
  • Type numbers can be very different from brand to brand. Sometimes an entire type number is just one digit or letter, and sometimes type numbers are very long numbers or long combinations of letters and numbers.
  • "Type numbers" go by different names, depending on the manufacturer. Some manufacturers call them type numbers, while sometimes they are called the: engineering number, series number, or bar code number.
  • Some model types are only distinguished by the year of the model.
  • Type numbers can be very difficult to find, sometimes located on the inside of a tool's housing (like some Ryobi tools). Fortunately, most type numbers are listed on the name plate with the model number.
  • When a manufacturer does not anticipate redesigning a tool or machine model, the first type of that model often does not have a type number assigned to it by the manufacturer. Designs that follow the first type will usually have type number designations.
  • Some manufacturers do not use a type number system at all, and instead change model numbers for each new design. In this case, the model number is the only number needed to match the right parts to the tool or machine.
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
Jan 19, 2010 | Porter Cable Air Tools & Compressors
I need solve this type calulation is 0,1,1,2,3,5,8,13,21,34 etc. u send me the code of this type of calculation in c++ language
Ok! Here's a snippit from some code I wrote in beginning c++ classes. However, don't just cut and paste it. Know how it works since it's important in algorithm examination!
Just tested it, compiles and runs perfectly on GCC 4.0.1 on my mac, as well as my linux boxen. Windows may take some changes to output data.
* Steven Parker
* Calculating Fib Sequence
* after two starting values, each number is the
* sum of the two preceding numbers
#include <iostream>
using namespace std;
int main() {
int whentostop = 20; //How many values of sequence to calculate
int fib[whentostop]; //Hold fib numbers
for (int i=0; i < whentostop; i++) {
if (i == 0)
fib[0] = 0;
else if (i == 1)
fib[1] = 1;
else
fib[i] = fib[i-1] + fib[i-2];
cout << "Fibonacci[" << i << "]: " << fib[i] << endl;
return 0;
Nov 12, 2008 | Computers & Internet
Land measuring
Just follow the steps....
  1. Type "Enter Land in Gundas" in A1
  2. Type "Equivalent Land in Acres" A2
  3. Type "=B1/40"
  4. Now type the number of gundas in B1 example 100
  5. you will automatically get 2.5 in B2
Now you need only two decimals tighy?
  1. Select B2 Cell
  2. Right Click and goto Format Cell
  3. Goto Number
  4. Under Number select Number Catogory
  5. and then select 2 decimals
Thats all
Jan 31, 2008 | Computers & Internet
Type 1 CF Cards
They will work. The only difference is the number of pins.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Fujitsu FPCKB41A1P Keyboard Logo
208 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
